IN NEED OF DESPERATE HELP PLEASEE!
Old May 1, 2015 | 08:08 AM
Sam L.'s Avatar
Car: 1990 Camaro Iroc-z Z28,1987 Camaro
Engine: 406 Super rammed SBC, LT1 355
Transmission: 4l60E, 700R4
Axle/Gears: disc brake 3.27 9 bolt posi,10 bolt
hey guys im back again im wokring on the 87' the infamous 90 iroc is finally done, anywho i pulled the ratted 305 out of the car everything went fine, i unbolted the tranny and bolted it up to my lt1 350 i just got done with. i drop it in which took very little effort slid the motor mount bolts in pullled the hoist out and braced the transmission, i stepped back and found my motor is sitting wayyy to the right so much so the trans tail is almost hitting the passenger side of the trans tunnel, the motor mounts on the chassis were reused from the 305 it did not sit crooked at all, i have no clue whats happening and i have to have the car done by next weekend for my college drag race event, my final one cause im graduating! please any help would be appreciated
Old May 1, 2015 | 09:07 AM
danryanm's Avatar
Car: '86 Trans Amvanian Frankenbird
Engine: 350 4bbl
Transmission: T5 4.03/.76
Re: IN NEED OF DESPERATE HELP PLEASEE!
Would reversing the brackets make a difference?
Old May 1, 2015 | 09:16 AM
Sam L.'s Avatar
i never took them off... but i just thought of this, what if i pulled the motor mounts off of the 305 and put them on the lt1 would that work???
Old May 1, 2015 | 12:35 PM
danryanm's Avatar
Engine: 350 4bbl
You should be using the original brackets from the car. Not all motor mount brackets are created equal, and they are specific to each side.
Old May 1, 2015 | 01:02 PM
Sam L.'s Avatar
Found the problem! my Lt1 was from a b body the pass side mount is off set to accommodate A/C, i moved the clamshell over to the A/C mount and flipped it and voila sitting straight will post pictures later tonight
Hellbillydeluxe
Sep 22, 2015 09:58 PM
camarochic
Mar 12, 2002 04:13 PM
maksik7
Feb 20, 2002 10:02 PM
IROCZ28KevinZ
Jan 13, 2002 10:37 PM
ChevyLuva3
Nov 3, 2001 08:46 PM
