l98
Old Jun 6, 2015 | 04:51 PM
xca's Avatar
xca
l98
I have a 1990 camaro with the 305 engine and want to swap the engine
with a L98 short block. Dose anyone know if the heads/intake from the
305 will work on the L98 block.
Old Jun 7, 2015 | 10:05 AM
Re: l98
Yup, bolt right up.
However, this is probably in the class of things where just because it can be done, doesn't automatically guarantee that it should be, or that it's "A Good Idea".
The heads on the 305 have very small chambers and very small valves. What you will end up with is a VERY high-compression motor that probably won't run anywhere near right on pump gas, and its performance will be VERY poor at any RPM higher than 2500 or so due to the restriction of the tiny valves. Altogether not a good combination.
What are you REALLY trying to accomplish? Rather than answer a vague yes/no kind of question, maybe we can offer constructive suggestions to help you get from point B, wherever that is that you are now, to point A, which is wherever you wish you were whenever you get done doing whatever you end up doing.
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
italiano67
Sep 22, 2015 08:42 AM
