4 tech motor
Old Oct 23, 2015 | 05:52 AM
s10 rodder's Avatar
4 tech motor
I have a 1987 chevy s10 2.5 4 tech motor rebuilt not even two months old I was driving last night and motor making a strange grinding noise like when u shift into a wrong gear my transmission seams fine but the motor is under warranty
Old Oct 23, 2015 | 06:43 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Re: 4 tech motor
I think you've got the wrong forum 😳
Old Oct 29, 2015 | 09:47 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: 4 tech motor
Take off the fan belt (belts?) and start it up, see if the noise is gone. Could be water pump or alternator maybe?
Old Oct 30, 2015 | 06:30 PM
s10 rodder's Avatar
Re: 4 tech motor
Well I took the belt off and it's still there I replaced the altnator bracket that was cracked in two and got it to start up but it sound like something internally that might be messed up like a bent valve or a bad piston ring might gone out or even spun a bearing somewhere when I hold the valve cover I can feel as well as hear it so could it be a bad valve
1Aauto
Sponsored Vendors
Nov 16, 2015 03:30 PM
gixxer92
Oct 24, 2015 01:26 PM
Piston454
Oct 23, 2015 03:36 PM
dibella989
Oct 21, 2015 07:53 PM
1Aauto
Sponsored Vendors
Oct 19, 2015 09:49 AM
