305 tbi how to pull.
Old Dec 25, 2015 | 06:19 PM
1nastyRS's Avatar
Car: 1992 Camaro RS under construction
Engine: Building 500 rwhp ls1
Transmission: 4L85E
Axle/Gears: Moser Ford 9" 3.70
I will be pulling my 305 tbi soon. Im wondering what all i need yo unhook/drain, and how to pull it out. Im sure i could figure it out myself, im just trying to make it easier. Thabk you.
Old Dec 26, 2015 | 12:02 PM
Pocket's Avatar
Car: 91 Trans Am
re: 305 tbi how to pull.
Leave the engine harness on the engine. Unhook the computer and pull the bundle from behind teh fender and drape it over the intake. Same from the drivers side
Drain fluids, unhook the lines, remove DS/y-pipe, unbolt crossmemer/K-member, separate centerlink from pitman arm/idler, remove strut upper nuts. Lift car off engine/trans
I didnt have a tool to separate ball joints so the steering box/idler came out too
Old Dec 26, 2015 | 08:43 PM
1nastyRS's Avatar
Transmission: 4L85E
Where does the k member unbolt from
Old Dec 26, 2015 | 08:48 PM
Pocket's Avatar
Car: 91 Trans Am
Bottom of the frame, 6 big bolts pointed strait up
Old Dec 27, 2015 | 09:52 AM
1nastyRS's Avatar
Transmission: 4L85E
Ok, i see a plug on passenger side plugged into something. Right in front of door. Is that the plug?
Old Dec 27, 2015 | 10:46 AM
Pocket's Avatar
Car: 91 Trans Am
Its the pass through. On the inside, there should be a plastic C-clip and a few tabs holding the assembly in place. Push it out into the fenderwell and pull it up by the blower motor. Its tricky but can be done
Old Dec 27, 2015 | 08:26 PM
1nastyRS's Avatar
Transmission: 4L85E
How does The steering box come of the column? How do I do the tranny?
Old Dec 28, 2015 | 12:23 AM
Pocket's Avatar
Car: 91 Trans Am
Leave the steering box alone. I took it out because i didnt have a pickle fork at the time
Undo the trans crossmember and DS. Trans will drop out with the engine
Old Dec 30, 2015 | 04:42 PM
1nastyRS's Avatar
Transmission: 4L85E
Its out! Thanks
AmpleUnicorn88
Members Camaros
78
Apr 13, 2016 07:36 AM
dpmalibu
Jan 27, 2016 07:44 AM
kanexpl
Jan 10, 2016 07:51 PM
JoeMama54
Jan 8, 2016 06:49 AM
xnickx64
Jan 1, 2016 03:35 PM
