INQUIRY: Combos that work (11 sec and faster)
Old Dec 31, 2001 | 10:19 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Old Jan 1, 2002 | 01:39 AM
CORKVETTE1's Avatar
1985 BAD *** VETTE
MODIFICATIONS
406 SMALL BLOCK CHEVY WHAT ELSE IS THERE
TRW FLAT TOP PISTONS
195CC AFR HEADS STOCK
1.6 ROLLER ROCKERS
ULTRADYNE CAM 223-227 DUR AT 50 460-480 LIFT 112LC
ACCEL SUPER RAM
BIG MOUTH INTAKE
58MM THROTLE BODY
24LB GREEN STRIPE INJECTORS
BOSCH IN TANK PUMP
ADJUSTABLE REGULATOR
TPIS COLD AIR INDUCTION
REBUILT 700R4 WITH SHIFT KIT
TCI 2650 STALL NO LOCK UP CONVERTER
1 3/4 INCH LONG TUBE HEADERS
CORVETTE FLOWMASTER MUFFLERS 2 1/2
BORLA REAR Y PIPE
MODIFIED MASS AIR FLOW METER
160 DEG THERMOSTAT WITH 4 1/8 INCH HOLES IN IT
UNDERDRIVE PULLEYS
STOCK CHIP
DANA 44 307 GEARS
HIGH OUTPUT COIL
MSD 6AL
WARP TIMES ON STREET TIRES THROUGH EXAUST!!
BEST AS OF 10-29-00.......DYNO RESULTS ASOF 9-25-00
ET=11:70...............................340RWHP
MPH=116.24..........................420RWTQ
60FT=1.60
1/8=7.44
(BEST ET ON STREET TIRES OPEN EXAUST)
1/8 MILE ET:7.37 MPH:92.66
1/4 MILE ET:11.57 MPH:117.37
EMAIL AT:CORKVETTE1@AOL.COM
http://hometown.aol.com/aheis46312/myhomepage/auto.html
Old Jan 1, 2002 | 12:08 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Old Jan 1, 2002 | 01:17 PM
CORKVETTE1's Avatar
forgot to add 22-23 mpg on highway
all the power works cruise ac everthing
take it on a couple of 300 mile trips a year too!
Old Jan 1, 2002 | 09:07 PM
MouseCamaro305's Avatar
1987 Camaro SC
ZZ4 350
Speed Demon 4 bbl
Rebuilt 700 R4 (heavy duty clutch bands, TransGo shift kit, etc.)
2,500 RPM precision industries converter
SLP headers, 3.5 inch exhaust all the way to the Dynomax muffler
3.73 richmond ring and pinion 7.5 inch 10-bolt
Hoosier slicks
150 HP by NOS
Timeslips on all motor w/ toyo proxes H-4 tires (15X8)
R/T- .276
60'-2.262
330-5.829
1/8-8.758
MPH-84.3
1/4- 13.2
MPH- 105.6
it's an extremely streetable setup, (nitrous is there when you want it, gone when you don't) the ZZ4 350 is more than potent, and as streetable as the LS-1. It gets about 12-13 MPG on the street, and I haven't really had it on the highway enough to measure its economy there, but it can easily be driven in all types of weather, (extreme cold and extreme heat) starts and runs as well as a brand new car.
Due to the weather here, the tracks are closed, and lm itching to test the 150 shot. I can guarantee right now that it will run 11's with the sticky hoosiers.
Old Jan 1, 2002 | 09:14 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: INQUIRY: Combos that work (11 sec and faster)
Old Jan 1, 2002 | 09:20 PM
now now, read carefully, it runs 13's on motor, do you honestly think it will be slower than 11's on a 150 HP shot of nitrous?
Old Jan 1, 2002 | 10:31 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Old Jan 1, 2002 | 11:39 PM
well, depending upon your suspension, tires, and ability to drive l really do think you should be able to pull off 11's once again depending upon your suspension, you may, with 650 HP be able to make it into the 10's, l have no doubt in my mind that the ZZ4 will be able to take the 150 HP shot, no problems at all. I used a 150 HP shot of nitrous on a 305 cu i TPI block, (stock internals) and got away with hundreds of nitrous runs and sevral bottles. the car was a 1990 IROC-Z, and l had faith in the motor, and l took good care of it. the runs go as follows:
Motor run:
R/T- .646
60'- 2.434
330- 6.579
1/8- 9.987
MPH- 72.31
1/4- 15.427
MPH- 90.41
Nitrous run:
R/T- .773
60'- 2.262
330- 5.829
1/8- 8.758
MPH- 84.33
1/4- 13.403
MPH- 103.6
the nitrous knocked off 2.024 seconds off my ET
13.2(ZZ4 350) - 2.024(N20) = 11.176
now l know the engines aren't nearly the same, but imo the nitrous should be capable of atleast 1.5 full seconds off my camaro's ET. (11.7) it will run 11's.........
crazeinc's Avatar
'90 GTA...full weight
350 4 bolt main
TRW Flattop pistons (~10:1 compression)
'66 Vette heads mild porting, gasket matched, 3 angle valve job
Crane 284 cam
Performer RPM intake
Holley 750 vac. secondaries
Edelbrock RPM nitrous kit 150 shot
13.2's on motor
Best was a 12.20@114...only pass I made with the nitrous at the track on a 255 radial
I used the nitrous on the street the entire summer and my engine is as healthy as it was when it first went together. I find this to be quite a nice and reliable combo...
Old Jan 2, 2002 | 12:13 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Old Jan 2, 2002 | 12:14 AM
20-psi's Avatar
1991 Mustang GT - origional shortblock w/190K 11.64 @117 on motor and 10.97 on a 175 shot.
Anderson cam 499.99 lift (to run Pure Street Class NMRA)
AFR 165 Alum heads (untouched)
Holley System Max upper and lower intake
Anderson Power Pipe
32 LBS injectors
BBK long tube headers into Flowmasters 2 chamber
Tremec 5-speed with SFI blow proof bellhousing
Full Custon Chromemoly 10-point cage
South Side subs frames
Mega bite SR's upper and lower
Auback launch kit with shocks and springs.
8.8 rear with 33 spline axle's with spool and 430 gears.
battery in rear.
1989 TTA - no times in the 11's but pulling away from the mustang on the street.
Pete
Old Jan 2, 2002 | 12:38 AM
nice vette, man
Old Jan 2, 2002 | 12:44 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Old Jan 2, 2002 | 01:21 AM
not real close, lm actually about 30-45 mins away from chicago, and about an hour away from union grove dragstrip. a few suburbs around me are buffalo grove, palatine, rolling meadows, mount prospect, elk grove, and schaumburg, l'm real close to woodfield mall.
Old Jan 3, 2002 | 11:40 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Old Jan 4, 2002 | 01:59 AM
20-psi's Avatar
I can't believe someone didn't say anything about my mustang post.
Pete
Old Jan 4, 2002 | 02:39 AM
Crazy Firebird Kid's Avatar
Car: 84 Trans Am
Pete
Well, I didn't see where Qwktrip said it had to be a third gen combo that worked, just a combo that works........and your does qualify
Old Jan 10, 2002 | 01:50 AM
O2BQIK's Avatar
Pete
Haha...isn't that always the mustang/f-body race? Mustang gets the ET, f-body gets the mph
Anyways since this has been opened up to non-3rdgens and cars that haven't proven themselves yet, here's my setup:
'99 Camaro SS M6
MTI Stage 2 heads
MTI B1 cam
MTI hardened pushrods
MTI airlid
Speedtek ported stock MAF and throttle body
LS6 intake
4.10 gears in stock 10-bolt
MAC headers w/ offroad Y and cutout
Flowmaster muffler w/ SLP quad-center tips
HPP3
MAF-Translator
393 horse at the wheels, and 374 rwtq with a bum lifter. New set of lifters go in next week. By the time the tracks open i'll upgrade the stock computer and get a new clutch, and it should hit 11's on motor.
Also MouseCamaro: if you run that nitrous on the track off the line, with those hoosiers, my $20 says that 10-bolt grenades. You need a 12-bolt for that kind of power, and I don't think you'll see 11's without one! Sorry to be a doubter
mbolte
Apr 25, 2008 11:21 AM
LoudmouthSS
Nov 1, 2006 07:05 AM
vortech305
Mar 16, 2001 05:02 PM
smithtc
Aftermarket Vendor Review
Mar 3, 2001 04:59 PM
RMK
Dec 26, 2000 12:24 PM
