Engine swap question
Old Apr 26, 2018 | 01:39 PM
Thirdvert89's Avatar
CAN I put a 88 5.7 tpi 350 corvette motor into my 87 gta that has a 5.0 tpi
Old Apr 26, 2018 | 03:03 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Engine swap question
Yes.
Old Apr 26, 2018 | 03:32 PM
As far as things plugging in and so forth no issues
Old Apr 26, 2018 | 04:44 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The oil pan and pickup needs to be changed.
You will also want to get a tune for the engine. The corvettes prom will work but vats needs to be eliminated in the tune.
You might want to use the corvette intake other wise you need to elongate the center four bolt holes. IMO the corvette base is better it has a coolant crossover.
If your in a emissions testing area the 113 heads don’t have egr provisions.
The egr feed is done from the manifold to the rear of the intake feed.
meanblackZ
May 7, 2002 11:36 AM
smurfmobile
Aug 19, 2001 12:55 PM
chooch-88formula
Jul 12, 2001 03:39 PM
JPrevost
May 13, 2001 11:36 PM
TomP
Feb 16, 2001 06:37 PM
