113 Heads with 2.02/1.60 Valves on a 305
Old Sep 9, 2018 | 07:00 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
I am currently running a 305 with the TBI heads and cam. The valve seals are starting to fail and I occasionally get a puff of smoke on start up. I have read mixed opinions on running the larger valves on the 305. Anyone know if it will be an issue if I swap these. I am also considering tossing a cam in while I have it apart.
Old Sep 9, 2018 | 07:40 AM
Re: 113 Heads with 2.02/1.60 Valves on a 305
Valves that large might not fit in the 305 bore. Might crash into the block deck. Even if they DO fit, which is far from certain, they will be shrouded by the bore.
Just change the 305 valve guide seals and save the 113s for a real motor someday.
Old Sep 9, 2018 | 10:01 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Agree. They will touch bore at like .430-.440” of valve lift, depending on exact valve spacing but it is not optimal. 1.94 is the biggest i would go
Old Sep 9, 2018 | 11:07 AM
91RS5speed's Avatar
Car: 91 RS
Thanks for the response. I am assuming you can't revert the valves once they are increased to 2.02/1.60.
Old Sep 9, 2018 | 12:24 PM
Not usually. Kinda depends on how thoroughly they were installed though, and if the seat & throat were cut back (such as with a Serdi) or ported. Which if they weren't, they're just eye candy anyway, and not doing a damn thing besides diverting people off the path who are easily distracted by shiny things strewn along the way.
Old Sep 9, 2018 | 12:57 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
There are a few hotrod articles floating around out there with dyno measurements. hopefully they are reporting real results, not just made up ones. but there is hope for your 305 should you are looking to gain some performance. A real motor would be an LT8, but then, you have lost the soul of what it means to be 3rd Gen. Here is one for example: http://www.superchevy.com/how-to/pro...-engine-build/
https://www.hotrod.com/articles/ccrp...-engine-build/
Old Sep 9, 2018 | 06:31 PM
NoEmissions84TA's Avatar
I have 2.02/1.6 valves on a 305 (.030" over) bore. BUT, the heads they are in are the World Products Dart S/R Torquer 305 heads.
Those heads use relocated valve spacing in order to do that. Heads with stock valve spacing will not allow valves that large.
And like Sofa and Orr89RocZ said, they will hit the bore and be severely shrouded. I notched my bores to help with that.
Here is a couple pics of mine: (Sorry, crappy old digital camera)
Attached Thumbnails 113 Heads with 2.02/1.60 Valves on a 305-combustion-chamber.jpg   113 Heads with 2.02/1.60 Valves on a 305-sunp0011.jpg   113 Heads with 2.02/1.60 Valves on a 305-sunp0013.jpg   113 Heads with 2.02/1.60 Valves on a 305-sunp0018.jpg   113 Heads with 2.02/1.60 Valves on a 305-sunp0042.jpg
113 Heads with 2.02/1.60 Valves on a 305-sunp0064.jpg   113 Heads with 2.02/1.60 Valves on a 305-head-gasket-fit-2.jpg
Old Sep 9, 2018 | 07:25 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Pontiac did that notching to a few block and head combos.
Old Sep 9, 2018 | 09:29 PM
LiquidBlue's Avatar
Transmission: MD8
That is pretty cool. When there is a will, there is a way!
Old Sep 10, 2018 | 06:12 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Some bbc guys have notched blocks to. Seems to be ok but rather would put the proper head on it
Old Sep 10, 2018 | 06:23 PM
In my case, it is the proper head. I did not receive what I ordered from RHS 25 years ago. I received 305 class racers heads by mistake. I discovered the 2.02/1/6 valves maybe 5 years ago when I finally took the engine apart to see why it failed. Incorrect, oversized valve seals plus 464 lb/in springs for my hydraulic flat tappet camshaft caused engine death after only 19,000 miles. There was no retainer-to-seal clearance, so while the seals were still soft, they worked. After a while when they became harder, the cam lobes became circles. That shrapnel went through the engine, destroying nearly everything. But, I was able to resurrect it and correct all of the other problems with the good advice I have found here on thirdgen.org.
Old Sep 10, 2018 | 08:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Did not receve what you ordered and it had wrong springs yet was the right head? Lol. Those class racer heads arent bad but i didnt think they came with 2.02 valves
Old Sep 10, 2018 | 08:32 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
https://www.speedwaymotors.com/RaceS...ads,64393.html
these dont seem bad for the money. 1.94 1.6 valves
Old Sep 10, 2018 | 10:55 PM
Yep, correct head casting, but modified by RHS for someone else. I received someone else's heads.
I ordered new 1.94/1.5 valves for them and knew something wasn't right when they fell too deep in the seats.
Old Sep 12, 2018 | 05:33 PM
LiquidBlue's Avatar
Transmission: MD8
https://www.castheads.com/info/gathe...e-performance/
Air flow facts on 305 heads.
Test head: ‘450 casting number Chevy 305 head with “UnderCover Porting”.
Air flow with 1.84″ valve. Ferrea # F5060.
.200 126
.300 173
.400 206
.500 212
.600 213
After the head was flow tested with the 1.84″ valve, we machined the valve seat to accept a 1.900″ valve. If all you look at the high end flow numbers, you would think that the larger valve was a improvement. However, the small improvement at .500″ and .600″ lift was more than offset by a sizeable reduction below that point. Air Flow with a 1.900″ valve Ferrea #F5072.
.200 124 -3
.300 170 -3
.400 198 -8
.500 214 +2
.600 215 +2
Test don’t guess.
Old Sep 12, 2018 | 05:37 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah just cutting a hole and stickin a bigger valve doesnt do anything unless entire port shape is modified to work with it
Old Sep 12, 2018 | 05:43 PM
LiquidBlue's Avatar
Transmission: MD8
wealth of info over here btw on 305/350 heads https://www.thirdgen.org/forums/tbi/...-headflow.html
Old Sep 12, 2018 | 09:39 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
I didn't know you could go that big on 113 heads?
Hows that setup run?
Old Sep 12, 2018 | 10:16 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
from what i seen 1.94-2.00 is best. Like the fastburn head has 2.00 valves. The 113 ports cant get too big like a lt1 head can and lt1’s do awesome with 2.00 valves
Old Sep 12, 2018 | 10:51 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
That's more in line with what I was thinking. I remember years ago in GM High Tech Performance (RIP) reading about a guy with an IROC that had a N/A 355 with 113s running mid 10s. And it seemed like he had 2.00" valves. Heads were done by Lingenfelter.
dabird07
Aftermarket Product Review
Oct 7, 2011 09:55 PM
WASyL
Oct 19, 2010 03:45 PM
FASTRED335
Jul 19, 2003 11:21 AM
onebinky
May 6, 2002 12:39 AM
