EGR from AIR tubes
Old Mar 24, 2019 | 02:50 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
EGR from AIR tubes
Question: Could the EGR be tapped off from the AIR tubes?
I'm looking at doing a 350 swap, but want to know if I can do a corvette style EGR tube (using a corvette base or even engine), and run a EGR tube from intake base over to the AIR system and tap off the same port which is already on the header instead of welding a new port to the headers. The headers plan to use are the ceramic coated hooker 2055's. I'm not sure why folks would weld a new tube on the header when this connection point is already available, unless it would screw with the AIR system.
Kempfs92
Jul 3, 2008 01:47 AM
Cadillac
Feb 16, 2008 07:49 PM
camaro89rs355
Feb 29, 2004 05:09 PM
CamaroX84
Jun 11, 2001 09:46 AM
