vortec or aluminum heads??
Car: 89 IROC Z
Engine: 5.7L
Axle/Gears: 2.77 PosiTraction
I plan on installing a 383 stroker in place of my L98. My heart says the cast steel vortec heads will suffice and there is not that much difference in cost to get the aluminum heads on a blueprint crate engine long block. I intend to install the First Performance TPI system on which ever engine I decide to purchase. Is there really that big an improvement with going with alum heads? I will be doing weekend street driving and an occassional auto cross with my 89 IROC, and hope to drive the car another 100,000 miles without issue
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: vortec or aluminum heads??
Each has their respective benefits but if the cost is similar chose the head the flows the most (assuming port size, CR and valve size is the same). Which aluminum heads are they?
Car: 89 Firebird
Engine: 355 TBI
You shave some weight with aluminum and the prices on some of them like procomps, blueprints, or Summit house brand aluminum are reasonable. IMO though for a build up to 300-325+ hp.. Vortecs are the way to go for the $ they are hard to beat and flow as good as a lot of aftermarket heads.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 89 Firebird
Engine: 355 TBI
Until their wafer thin decks crack the first time you mildly overheat the thing. Even something like an out of the box Assault racing head is a drastic improvement over a factory vortec. I have witnessed cracking in multiple locations, dropped valve seats, valve guides off center, guides that are too tight on clearance and pulled rocker studs on stock Vortec engines. The Hecho en Mexico 062s also do not even reach 220 cfm of intake flow.
Car: 2021 LT1
Engine: Lt1
Transmission: Tr6060
So now the best factory head GM ever put on a Gen 1 SBC is crap since you got some knockoff Chinese aluminum heads.. I wont argue with you Fast I'm sure you are gearing up to tell me how they done on a swap in a G20 van. Dang that van has had 100 different engines and combos in it Lol
Car: 1983 G20 Chevy
Transmission: 4L60
All I am saying is you can get a lot more out of an aftermarket casting and have better reliability at the same time. The Chinese are turning out some very nice castings now.
The Assaults are actually on my Express van. In the last 8 years it is actually the 2nd set of aluminum heads I have had on it. The Edelbrock Etec 170s were also very nice and I still have those heads on a 305.
Those Chinese knock off heads are making ~500 hp out of a 80K mile factory L31 350 bottom end with a small 215/224@ .050 cam (Degreed out at 218/228 @ .050 with 1.7 rockers) and flow better than many LS factory offerings. After LLoyd ported them those Chinese 23* heads flow as well as a set of ported Cathedral port LS heads.
BEFORE
LIFT------INTAKE-----EXHAUST
.200----------135-------103
.300----------183-------131
.400----------225-------150
.500----------244-------164
.600----------241-------175
.700----------241-------177
AFTER
.200----------138-------107
.300----------192-------138
.400----------241-------164
.500----------274-------183
.600----------291-------193
.700----------295-------199
Car: 89 IROC Z
Engine: 5.7L
Thank you all for your responses. In particular, I do not know the aluminum heads manufacturer other than Blueprint engines supplies them on their 383.. My major concern is I want a 100, 000 mile engine but yet an engine that can take an occasional autocross run.
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
Beware of the "stock" Vortec heads lift limit. It's only around .470ish. There are many ways around it though.
bigblak
Jul 15, 2011 05:11 PM
MatthewH
Jan 19, 2001 01:29 AM
