LS swap oil filter relocation
Old Aug 12, 2019 | 12:23 AM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Hey guys was wondering where a good spot would be to relocate my oil filter?? I'm using this kit from speedway has all the fittings and plugs plus 6 feet of hose. Could I get away with drilling a couple holes and using self tapping screws to hold the adapter to frame or something?? All opinions welcome. Thanks in advance
Attached Thumbnails LS swap oil filter relocation-screenshot_20190811-222028.jpg
Old Aug 12, 2019 | 07:52 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: LS swap oil filter relocation
Mount it where it will be easy to get to, and won't make a huge mess every time you change the filter. Additionally, I wouldn't trust mounting such a critical component with self-tapping screws; use bolts, lock washers and nuts instead.
Of course, it should go without saying to make certain to route the lines away from exhaust components as well as steering and suspension parts.
Old Aug 12, 2019 | 11:00 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
I'm curious why do you need to relocate the filter? I can't think of a reason unless you are running a dry sump or external oil cooler that uses the stock location as the attachment. You also may want to consider not mounting it higher than the oil pump to avoid strain on the pump.
Old Aug 12, 2019 | 11:48 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
It's a turbo build. He probably wants a larger than stock filter, or the pan has large kick outs.
Old Aug 12, 2019 | 05:42 PM
thatsupnow's Avatar
It's a bigger fabricated steel pan that uses -10 an fittings for oil in and out
Old Aug 12, 2019 | 05:44 PM
thatsupnow's Avatar
Yep it's a turbo build. The oil adapter has 2 filtered 1/8" npt outputs on it
Gsoleski
Apr 25, 2013 11:46 AM
Bradlyj8Z28
Jul 25, 2010 09:47 PM
TA-Rocks
Feb 19, 2009 10:07 PM
PonyKiller87
Aug 5, 2004 11:05 AM
