Camaro 305 tbi to 350 tpi engine electrical problem (wont start)
Hi guys.
I have a camaro 91 that had a 305 tbi and now have a 350 tpi and 7730 ecm (vats is disconnected) with a firebird engine harness. Security light goes and and off after a few seconds. The problem i sthat it cranks but wont start. The fuel pump doesnt engage with the ignition and the check engine light wont go on either. I checked the power cable and ground to the ecm and it is there anyway. I have also tested the fuel pump directly to a battery and it works and well. What am i missing?
Thanks in advance
Thanks in advance
Car: 1991 base firebird
Engine: tbi 305
Re: Camaro 305 tbi to 350 tpi engine electrical problem (wont start)
is it trying to fire? you double check firing order? make sure plug wires aren't crossed somewhere? timing 180 out?
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
did you trace those unconnected wires. from a quick glance at your pics, that disconnected connector looks to me like it might be to an individual fuse holder, ie the connector holds a blade type fuse and may be why you are not getting power to the injectors. i would ring out the connection and see where the orange wire goes to. look at the schematic and you should be able to quickly narrow it down
