Vortec TPI coolant bypass
Old Nov 28, 2019 | 10:30 AM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
Okay folks, please correct me if I'm wrong, but it seems to me that the stock heater core diverter valve already accomplishes the same thing as running an extra hose to the water pump. When no heat is called for, the stock valve diverts coolant from the restricted nipple in the front of the intake manifold directly back into the passenger side top of the radiator. Would this not provide some coolant flow through the engine/heads until the thermostat opens? Is the problem that it would not provide enough flow? I have attached a diagram showing the correct (I believe) coolant flow path(s). Keep in mind, also, that the throttle body coolant hose has been deleted, so the diverter valve hose connects directly to the restricted intake manifold outlet.
CamaroIROC88350
Jul 21, 2010 02:03 PM
patricksmithahh
Dec 15, 2009 07:38 AM
bwtaylor84
Jun 2, 2009 06:56 AM
SLP IROC-Z
Feb 10, 2004 11:55 AM
bigals87z28
Jan 22, 2003 12:28 AM
