4.8 5.3 mates with t5 required parts?
Old Feb 5, 2020 | 09:34 AM
zrafferty's Avatar
I currently have a 91 camaro with t5 and 350.
was thinking of doing an ls swap with a 4.8 or 5.3 bs rebuilding my 350.
i have read I need a 621 bbc bell housing with ls flywheel.
is there anything else I would require would prefer to use the original clutch with external slave .
Old Feb 5, 2020 | 09:55 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: 4.8 5.3 mates with t5 required parts?
I think you need the thick flywheel to make it work, it's a Sachs 1050. The T5 bellhousing will actually bolt to the LS engine, but it may not fit the flywheel. the 621 bell is going to rotate your T5, so that won't work, plus there is no provision for the external slave on the 621. You're stuck getting the Lakewood bellhousing if the stock T5 doesn't fit over the clutch and flywheel
Old Feb 5, 2020 | 10:15 AM
zrafferty's Avatar
Will Lakewood design as a plug n play.
debating on ls swap or rebuilding my current 70’s 350 sbc vs prices I can get a 5.3 complete for 300 local
Old Feb 5, 2020 | 10:24 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Not sure what your post is about, but if you're asking if it is a direct replacement for the stock bellhousing, then yes
https://www.holley.com/products/driv...et/parts/15020
https://www.summitracing.com/parts/lak-15020/overview/
Old Feb 6, 2020 | 10:07 AM
zrafferty's Avatar
Ouch for 700 I guess I would be better off rebuilding my 350 makes 360hp with 370 torque considering I am not planning on doing any performance upgrades and keeping it stock for time being.
Only thing I have to find is a complete exhaust to put on her.
Do you guys have any suggestions for cheap complete exhaust headers back .
I look only I can only find 2nd gen complete nothing but can't back for 3rd.
I only have headers on car now. I believe they are 3 bolt flange been a few months due to snow and have to verify diameter
Old Feb 6, 2020 | 10:46 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
You can search for 4th gen cat back systems, it's largely the same and there are a few more options. Hawks will show most of the available 3rd gen cat back systems though
Old Feb 7, 2020 | 09:18 AM
zrafferty's Avatar
When searching that’s all I am finding is cat back as one kit then headers with ypipe for 2nd kit nothing ypipe back
Old Feb 7, 2020 | 09:20 AM
zrafferty's Avatar
Would prefer cheapest exhaust to make this baby’s street legal nothing fancy I’m not one that cares about exhaust notes they tend to sound same to me.
Old Feb 7, 2020 | 10:10 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I don't know how or where you're searching but these are just a few examples
https://www.summitracing.com/search/...xhaust-systems
Old Feb 7, 2020 | 12:57 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
the 621 will bolt up but won't work with the t5.
you need to grind some stuff down on the lakewood to bolt to the back of the LS and then you most likely want headers if so long tubes wont fit with the slave cylinder mount,
i'm using a lakewood t5 scattershield on the back of a 6.0 with an LS7 clutch kit, tilton hydraulic throw out bearing and a tremec tko 600
the LS is far superior than the older engines.
Old Feb 7, 2020 | 12:59 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I forgot about that, The 3 topmost bolts on the rear engine cover touched the bolt heads.
Old Mar 13, 2020 | 09:20 AM
zrafferty's Avatar
Yea I’m on tight budget so trying to find best route even if it’s temporary.
i know everybody states you can’t use a t5 with a 350 it will only last a month
me and my grandfather both have a t5 behind 350 and haven’t blown anything.
didnt know if it same for ls setup or if it truely can be done without blowing tranny
Old Mar 13, 2020 | 02:40 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Although your average LS makes far more power than your average 350 its not power that kills drivetrains. Traction kills rears/transmissions. If you go easy and don't dead hook with sticky tires you shouldn't break anything. But what fun is that?
Old May 24, 2020 | 08:23 PM
zrafferty's Avatar
Mine I’m building as a cruiser and a toy but not gonna abuse it.
found a dual exhaust which I ordered from summit it’s a 2.25in true dual now saving up little by little for rebuild kit for 350 at 160 exhaust coated me 207
sgp0511
Apr 12, 2016 08:39 AM
shinzon1
Aug 22, 2011 09:24 AM
davidz28
Apr 6, 2009 12:17 PM
digitalrebel
Feb 3, 2008 12:19 PM
Speedemon171
Jul 5, 2002 10:55 AM
