AN-8 lines on top of tank
Old Feb 8, 2021 | 08:06 PM
CKRacing's Avatar
Car: 1984 Camaro
Hi,
I'm planning on buying an Aeromotive "direct fit" tank for Third Gens that comes with a 340 LPH pump. I wanted to run 1/2 hard line and for soft line, AN-8. The only places I want to run PTFE or rubber line will be the tank down to the body and from the regulator to the rails. Does anybody know if braided AN-8 lines will fit on top of the tank when it is installed in the car. I would like to avoid doing the trap door mod if it dosen't fit, so I would probably just end up running hard line on top of the tank if it's a problem. Just wondering if anyone has done this yet.
Old Feb 9, 2021 | 07:40 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: AN-8 lines on top of tank
The tank comes with -6an extensions so you'll need an adapter. How much power are you planning on running? -6 should be all you need that the pump can provide. Aeromotive has told me this tank is good for about 700 HP N/A. Less with boost.
Old Feb 9, 2021 | 08:02 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
-8 lines fit on top of my stock 4th gen tank fine
Old Feb 9, 2021 | 10:20 AM
CKRacing's Avatar
Car: 1984 Camaro
Im only going to be running about 570 HP at the moment but I plan to eventually do something else. I figured the 1/2 hard line isn’t too much more, so may as well only do it once. But I might just end up going with -6 AN for now. I would use the stock lines but they’re pretty rusted out and I don’t trust them at 60 psi since the car use to be carbureted.
Old Feb 9, 2021 | 11:18 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I had sstubes.com make me a repro 1/2" feed line in stainless without the end fittings for my car so I could run a -8an front to rear for my car. I am going to use the 3/8" SS line for the return
zacharyhorn
Aug 18, 2011 09:30 PM
zacharyhorn
Fabrication
Jun 9, 2011 03:34 PM
zacharyhorn
May 25, 2011 08:05 PM
onebad82z
Nov 14, 2002 12:45 PM
