Which Stock Lines Do What?
Old Mar 10, 2021 | 04:26 PM
Connor Bartley's Avatar
Car: 1989 Camaro RS
Engine: 5.3 LS
Transmission: Powerglide
Hello everyone, I've been on here before, asking all sorts of questions you have all given me generous answers to. I got a new sending unit for my stock 89 RS' tank, and i installed it and now finally have my 5.3 LM7 in the car. Got new rubber lines and new AN fittings on the fuel lines on the truck injection. I'm running my lines and hanging them up, but which of these gas lines on the stock sending unit is what? I know there is a feed and return, and vent, is the 4th for the fuel filter? If someone could edit my photo or point it out to me "for dummies" i would appreciate it. The car is almost done and i cannot wait to share it with you all on here!
EDIT: I was also told i need a "corvette fuel filter and regulator" from a friend, but someone on this forum said NOT to because i am using the STOCK return style truck intake. I i have is the stock in line fuel filter. Am i doing that right?. Do i need an aftermarket regulator?
Old Mar 10, 2021 | 04:40 PM
BIRD91ZRAG's Avatar
Re: Which Stock Lines Do What?
First question, what pump are you using with the stock sender?
kestell123's Avatar
Car: 1991 camaro convertible
Engine: LS3
Transmission: 6l80
Axle/Gears: Ford 8.8 3.31 torsen t2r
You feed or fuel out line goes to the filter , the one you're not thinking of is the charcoal can.
Old Mar 10, 2021 | 07:19 PM
Car: 1989 Camaro RS
Engine: 5.3 LS
Walbro 255
Old Mar 12, 2021 | 08:48 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
From the left on your photo. Vent, charcoal canister, return, delivery. Also, I think the delivery line needs an O ring. Am I correct on that?
Old Mar 12, 2021 | 03:06 PM
Car: 1989 Camaro RS
Engine: 5.3 LS
THANK YOU, NO BODY could tell me them from left to right, and yes if im not mistaking the delivery gets an o-ring. Thank you again!
Connor Bartley
Dec 23, 2020 08:42 PM
MiROC_89
Aug 6, 2018 05:36 PM
i8myz28
May 26, 2006 08:27 PM
Fastbird
Feb 23, 2005 04:29 PM
