Length of SBC+T56 vs. LS3+T56 (Connect & Cruise)
Old Nov 9, 2021 | 01:52 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I had a SBC and a T56 from a 93 TA in my 91 Z28 for a few years.
Long story short. That stuff is out, new setup is going to be an LS3 and new trans, and bought new from GM.
The old T56 needed the shifter hole extended 2". But it was a bit of a mess with making a shifter boot.
Looking to understand where the shifter will end up this time around.
I welded the entire shift hole shut for now while it is on my rotisserie and will go back and find a nice lower universal shifter boot.
Don't plan on having the motor till sometime in '24. This is just up front research.
Thanks for any help that can be provided.
Old Nov 9, 2021 | 05:23 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Length of SBC+T56 vs. LS3+T56 (Connect & Cruise)
A lot will have to do with your motor and trans mounts. My LS3 block and magnum combined with UMI kmember and mounts put the shifter perfectly in the original spot. However, with the Holley mounts it was farther back.
Old Nov 9, 2021 | 05:31 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I came across some of my old notes and I know I have a dimension sheet somewhere for the different 6 speeds.
Shifter Locations BellHousing to Shifter CL
F-Body - 29.5"
CTS-V - 35"
GTO - 33"
Magnum in f-body is 1.5" longer - 31"
Holley Mounts move engine .5" forward - 30.5"
Old Nov 9, 2021 | 08:29 PM
Engine: LS3
I was planning on using the holly double hump trans mount and stock k-member. Think it will be close to stock?
Numbah-1
Apr 12, 2016 12:27 PM
Ilike2stroke383
Feb 18, 2010 08:51 PM
mult68
Oct 3, 2004 08:17 PM
arec2001
Jun 23, 2003 09:58 PM
'91 Formula
Dec 29, 2002 09:15 PM
