LS swap won’t start
Car: 87 Camaro Multi-port Fl
Engine: Ls 5.3
Transmission: 4L 60 E
LS swap won’t start
87 Camaro 2.8 Multi-port Fl I’m doing a LS swap in LS 53 4L 60 E transmission standalone harness I am getting power at the coil packs Injectors but cranking the car over and testing with a test light the test like a super damnmon the coil packs why cranking I’m losing voltage somewhere car cranks over but don’t start first LS swap ever need a little bit help out there please and thank you and I’m trying to figure out if this car came with VATS System or not because I do not have a relay on the side of the kick panel on the driver side
Engine: Ls 5.3
Engine: Ls 5.3
Engine: Ls 5.3
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: LS swap won’t start
Engine: Ls 5.3
I have a chassis ground from the harness and a ground from the back of the head from the harness to and two Red wires for power to The starter and what do you mean by ECM properly grounded does computer need to be grounded to some that’s what you’re saying because I have those three things Grounded that came with the harness
Engine: Ls 5.3
And how do I troubleshoot it on my own
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Is the ECM you are using right out of a truck? If it wasn't flashed to get rid of vats it likely wont fire.
Engine: Ls 5.3
it came out of a 2003 Tahoe and I sent it to the place I got my harness from and they were supposed to delete that but they probably didn’t I don’t know how much does it cost to do that
Car: 1988 gta
Engine: 5.7
Axle/Gears: 3.27 posi with discs
I ran into a similar problem when I did an LS swap on my bosses truck, I had one of the pink wires (which are normally key hot) wired to the ignition switch in a way that the power went away in start but was there in run.
Engine: Ls 5.3
Did you ever figure out what the problem was and how to fix it
Car: 1986 IROC Z
Engine: 5.0 TPI
I don't know what to tell you that wouldn't involve writing a book.
Start with the basics. Fuel, spark, air intake and compression---all at the right time---is what's required for an engine to run properly.
Engine: Ls 5.3
Car: 1988 gta
Engine: 5.7
It's been said already. Start with the basics. Air, fuel, spark.
spark would be easy to check with an old plug and a friend. Pull one of the plug wires off of the plug in the head and put the old plug into it. Ground it with vise grips or maybe some jumper cables , in a way that you can see the electrode and watch it as your friend tries to start it. You should see a very small spark where it's jumping the gap.
Fuel check fuel pressure first, a fuel gauge is recommended. They have a service port in the rail usually, but if you need to you can pull the feed line off and aim it into a container and spin the engine over. It won't tell you if you have pressure but if nothing comes out then you know the fuel pump isn't doing its thing. If you determine you have pressure look for injector pulse with a noid light or fold the wires back on a 3056 bulb and put the wires into the injector plug in a way that it completes the circuit so that you can spin the engine over and look for a injector pulse.
for Air usually make sure you didn't leave a rag or block off plate in the intake and then do a compression test for at least one cylinder on each head.
For quick results and to move this whole process forward try starting fluid first. If it tries to run on starting fluid or it does run on it then something in the fuel area is the problem.
