88 350 into a 91 305 car
Old Nov 11, 2024 | 07:31 AM
SpeedFreakGT's Avatar
I've got a 91 305 TPI that's MAP and running on 7 cylinders but I have a complete 88 350 that's MAF.
can I just install the entire intake, plenum and runners off the 305 map engine onto the 350 MAF block and be good?
I do have a computer for a MAP 350 engine to install to.
Old Nov 11, 2024 | 08:05 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 88 350 into a 91 305 car
Drivers side runner , plenum, tb and injectors could be swapped , use a aujp or anjf chip in the speed density ecm.
Old Nov 11, 2024 | 08:50 AM
I'm sorry if I ask a dumb question cause I have no idea about any of this swap.
So I couldn't pull the entire intake system off the 305 and put on the 350?
Also I bought a computer for a 91 350 automatic, i would still have to change a chip?
I appreciate your help and info.
Old Nov 11, 2024 | 09:05 AM
Engine: Lb9
Transmission: M20
you could swap the entire intake but injectors need to be 22#hr not 19#hr.
Old Nov 11, 2024 | 10:17 AM
gotcha. The engine I'm getting has those so I can swap them.
I just found out it's actually a engine I believe you have tuned on at one point and I bought the 350 auto computer from you.
I appreciate all your information.
polymer52
Dec 4, 2012 08:34 PM
WhiteKnight
Nov 3, 2004 09:17 AM
gchu
Feb 7, 2004 06:47 PM
Viprklr
Apr 17, 2003 02:02 PM
Wes B.
Apr 23, 2002 10:33 AM
