Ls swap fuel pump & intake
Old Dec 9, 2024 | 01:15 AM
87.Pos's Avatar
Hello. I’m just about done with my 5.3 Ls1 swap into my 1987 Camaro RS and I have just a couple questions about products to buy that someone here might know. First fuel pump: im aware an ls1 needs a fuel pump putting out approximately 50GPH, should I buy a 4th gen z28 fuel pump from rock auto there only about 30 bucks. Or should I spend more and go with someone like racetronix ($200) would the 4th gen one even fit? Secondly: intake I unfortunately lost my stock style intake so I’m looking for a aftermarket cold air intake, and I just can’t find a good one that is actually boxed off so it picks up cold air. Almost wondering if I should replace the stock one but there not cheap, and I also heard they can limit air flow to larger engines. Thank for any ideas😁
Old Dec 9, 2024 | 10:48 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: Ls swap fuel pump & intake
get a genuine walbro 255 from summit racing. its about 110 bucks with install kit. A 01-07 silverado cai will fit in the thirdgen. you will need to modify the air box
Old Jan 5, 2025 | 03:14 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Unless you've got Triple A I would stay way way way clear of Racetronix pumps. They're garbage and they over hype them. I was dumb enough to keep giving them money after 2 pumps were DOA, 1 died after 3 weeks and my last one I managed to get 4500 miles on before it gave up the ghost. Now I run dual Walbro 350 g3 pumps
58mark
Apr 28, 2014 10:55 PM
DerrenZ
Apr 23, 2014 11:02 AM
Mitch91Z28
Aug 18, 2011 04:30 AM
Mitch91Z28
Aug 14, 2011 05:24 PM
tlove
Jul 23, 2007 09:31 PM
