350 engine swap question
Old Feb 5, 2025 | 05:16 PM
Jacobvanhorn's Avatar
I am curious about the harness situation. I dont want to use the stock harness setup thats currently in my firebird for the engine bay. Is there an easy and or better way to have a harness work with a new 350. I want to use a long block crate 350.
Old Feb 5, 2025 | 05:20 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: 350 engine swap question
What do you have for a car?
Old Feb 5, 2025 | 05:23 PM
so I dont have anything yet but I want to get the long block from
blueprint or summit and its the one with 341 hp but I want to make it carbureted but Im not sure if an electrical water pump would be better then mechanical. And not sure what distributor i should get. I just need a better idea of what I should get. I dont want a stock 350 from a used car. I saw the thread about that
Old Feb 5, 2025 | 05:24 PM
its an 87 ta
Old Feb 5, 2025 | 06:38 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
What's wrong with your stock harness?...
Old Feb 5, 2025 | 06:42 PM
I really just wanted a simplified harness. The way it comes from the factory is just a mess. And to be completely honest I dislike it so I was hoping I could have something different in the car
Old Feb 5, 2025 | 07:10 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
I'd recommend building your own harness...that way, you get what you want.
Old Feb 5, 2025 | 08:50 PM
T.L.'s Avatar
Well the original harness on my '83 wasn't "a mess". If you are going with a carb, simply remove (not cut) the harness that runs through the passenger side fender apron to the ECM, and just keep the main engine & lights harness from the driver side firewall next to the brake booster. Clean it up (like I did) with new split wire harness tubing, and black zip-ties where needed. This advice is of course based on a stock wire harness that is in decent condition and hasn't been fornicated by previous owner(s)...
Old Feb 6, 2025 | 07:51 AM
Ok thank you! The wiring in the engine bay doesnt seem to be hacked away besides the fact that I just spliced and installed a switch so my cooling fan would operate
maroe624
Feb 13, 2024 05:16 PM
chevy_dude97
May 16, 2012 03:56 PM
krzyz
Mar 11, 2012 09:45 AM
Moonlight
Feb 10, 2009 03:08 PM
ph0nix86
Jul 14, 2004 01:08 AM
