Using oem serpentine setup with double hump heads
Hey everyone. I have an 88 gta. Im swapping out the locked up tune port that was in it for a 355 with a carb ive built. Im going to be using a set of 186 double hump heads that have holes for accessories. Am I going to run into any issues when trying to reuse the original serpentine setup including the ac? Any input is appreciated thanks
Re: Using oem serpentine setup with double hump heads
Nope. AFAIK all the holes you need are there, with one possible exception, which if you need it, you can drill & tap it.
66_C10_TPI
Aug 29, 2003 11:35 PM
