Original car VATS with LS1 Swap
Car: 1989 Firebird
Engine: 2001 5.7 LS1
I have a 1989 Firebird that had a 2.8 V6 in it with VATS, my question is do I need to do anything with the pass key or anything else? The new engine will be using a 2001 computer and a stand alone harness. I will also be using the stock gauges with the c100 harness and tach and speed from the computer
Thanks Rich
Thanks Rich
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Re: Original car VATS with LS1 Swap
Car: 1989 IROC-Z
Engine: L98 350 TPI
You'll need to bypass the start enable relay, and possibly tune out VATS from the new ecm.
Car: 1989 Firebird
Car: 1989 Firebird
I am not sure why I didn't find it with my past searches but I found a great write up by QWKTRIP
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Car: 1989 Firebird
I printed it and now when I try and search I am unable to find it, the title is How To Bypass VATS by quicktrip April 8th 2018
https://www.thirdgen.org/forums/elec...pass-vats.html
I don't know why but I found it under defeating VATS
Last edited by upstateRich; Sep 19, 2025 at 04:53 PM. Reason: found more information
