Basic Clutch/Flywheel Install Help
Old Jan 25, 2002 | 08:50 AM
onetontj's Avatar
Thanks for any help...
1) Can I re-use flywheel bolts without any worry?
2) What is the torque spec on the fly wheel bolts?
3) Can I use regular grade 8 bolts to bolt my clutch to the flywheel?
4) What is the torque spec on the clutch to flywheel bolts?
5) How do I torque the flywheel bolts down without the engine turning? I was going to hold the crank by the bolt on the front but recently read a bunch of people have stripped those out by turning the crank...how much are those flywheel holders?
Thanks.
Old Jan 25, 2002 | 12:50 PM
Guest
Guest
Posts: n/a
Re: Basic Clutch/Flywheel Install Help
Yes.
Yes, but I would buy a set, I suspect one or two may have different size shoulders on the bolt. Dorman makes a kit.
Not positive, but its not a whole lot.
Old Jan 25, 2002 | 04:41 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Chiltons says 50 ft-lbs for the V6 and 60 ft-lbs for the V8.
Pete
Old Jan 25, 2002 | 08:01 PM
Guest
Guest
Posts: n/a
I'd try to check that number, seems to me its not anywhere near that much. 60 ft-lbs is bound to break the bolt.
Old Jan 25, 2002 | 08:40 PM
87RS402's Avatar
I've always just used the tight guideline, get tehm tight and go on to the next step.
BTW, tight for me is around 40 ft-lbs.
Vintageracer
Jan 10, 2020 05:33 PM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
