1986 iroc TPI to carb
Car: 1986 iroc Camaro
Transmission: Manual TKX
Axle/Gears: 370
Hi Guy’s I would appreciate some advice, I put a 350 in my 1986 iroc and have attempted to go from a TPI setup to carburetor, the plan was to use the existing fuel injection tank pump and then use a regulator to adjust the pressure for the carburetor, . I’m nervous about running a regulator as if it fails I’ll have a flooded carburetor and possibly a fire . Is there a way to use a mechanical pump with the current tank lines ? Thank you
