intank FI pump for carb
Old Apr 19, 2003 | 12:18 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
today my buddy was tellin me that there is an inline regulator that will allow you to use your FI pump....it recieves the incoming psi (what that may be) and it limits it 7 psi or what u need. Its send the excess fuel back to the tank using the existing return lines....
anyone ever used one?
Old Apr 20, 2003 | 09:58 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I use a Mallory AFPR and I think it works just fine. Part # 4309 at Summit.
Old Apr 20, 2003 | 02:39 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I use the same Mallory regulator mentioned about and it works fine.
Old Apr 20, 2003 | 06:30 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
my car came with tpi and im going to carb....im talking baout the regulator that you can use with the existing intank pump for tpi fo a carb...
i dunno u guys may be talking about the same thing...
Old Apr 20, 2003 | 06:34 PM
Blackroc86's Avatar
Car: 1986 Iroc
My car was originally a TPI car and I switched it to a carb. I am using the stock intank pump with the mallory 4309 to cut the pressure back to 7 psi with the excess returning to the tank through the normal return line.
Old Apr 21, 2003 | 07:27 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Mine used to be tpi also. I run the set-up just like Onyxdawg.
Old Apr 21, 2003 | 10:59 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
ok guys looks like u were talking about the one i was lol....
were did u guys get them from? the part number anbd the price...
thanks guys!!!
Old Apr 21, 2003 | 12:24 PM
Blackroc86's Avatar
Car: 1986 Iroc
It is a Mallory part number 4309 as Todd200 posted earlier in this thread. I got mine from Summit.
Old Apr 26, 2003 | 09:16 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
2 pumps?
what will a stock pump support power wise?..
i was thinkin, if i have to put a regulator in the lines why not put in another pump..instead of having either one working hard have 2 that are not working at all...
what do u guys think?
Old Apr 26, 2003 | 10:44 PM
Blackroc86's Avatar
Car: 1986 Iroc
It is your choice. I gteched my 406 this spring and it ran a 12.286 at 115.95 so I think the regulator support a fair bit of power.
Old Apr 27, 2003 | 08:44 PM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
Yeah, that pump won't be working very hard at all. It's made for higher pressure apps, so the load on it will be quite low compared to what it was with TPI. Just get the three port regulator. Do NOT use a 2-port or your pump will fry. It's very important for in-tank pumps to have a return feed. If your pump ever goes out, then you can go with an external pump, and you'll still have an excellent regulator. I'm running a Holley in-tank pump now with no probs (of course, I haven't really driven it much). James
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
