best way to go? money in engine or shortblock...
Old Feb 6, 2002 | 02:46 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
hey guys,
the 305tpi in my '86 IROC is toasted.. I'm gonna put a 350 in probably in about 2 months.. what's the best way of going about this?
I have about 750 to spend right now. I can get a cheap 350 that's rebuilt and ready to drop in for $495 down in San Fernando or I can go down there and get a bored block with crank, rods and pistons and take it to a shop and have it balanced for about 650..
the engine for $495 is a longblock but the one that would be balanced would cost me about 650 because I would be getting it unassembled (cheaper) and then balanced (more expensive)..
which way should i go? it'll cost a bit more to do it the better way but I need to do the job fast.. as well, i will be going later with some aftermarket heads, probably the World Products or something similar..
ideas? what oil pump? cam? the engine for $495 comes with a cam but what would be recommended for a daily driven 350 in SoCal? the cam will be roller..
thanks!
Colin Opseth
Old Feb 6, 2002 | 03:36 PM
Disturbed's Avatar
well if you are going to buy a short block and kep the TPI I would go with Vortech heads, Comp cams Hydrolic roller cam, roller lifters/rocker arms, as far as the oil pump I'd go with a high volumn one probably melling, they make a good pump.
hope this helps
Old Feb 6, 2002 | 05:58 PM
Disturbed's Avatar
BTW you will have to replace your stock fuel pump because it wont have enoguh pressure for the 350 TPI's injectors
Old Feb 6, 2002 | 11:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What?
All you need to do is adjust the pressure via an adjustable fuel pressure regulator. The pumps are the same.
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
toronto formula
Nov 10, 2015 06:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
