Gonna Buy The 330hp 350 From Gm - Ideas???
Old Feb 6, 2002 | 11:46 PM
strictlypirated's Avatar
Listen, Im only 15, my step-dad's a mechanic, and I have annoyed him enough lately asking questions, so I turn to my faithful message board.
http://www.mortec.com/sbcratemotors.html
The description on this site of GM's 350 engine with 330hp says I need intake.
After I get the engine, I am gonna change the cam, headers, maybe chip, etc. Someone please take a look at this engine for me, and tell me what I am gonna need to buy.
thanks
Old Feb 7, 2002 | 10:06 AM
zerogauge's Avatar
it says right there on the page what you need, even provides part numbers for the crate motors one of which is a longblock with intake carb hei flexplate and some other stuff. you need to read the webpages you link for the information you need rather then have someone else look for it....
lemme guess, you want us to come install the motor too?
Old Feb 7, 2002 | 12:34 PM
i read the page, I am asking for specific brand name parts, high performance stuff.
Old Feb 7, 2002 | 01:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You need to understand what you're getting. We need to know what you're putting it in, what induction you intend to use, and whether emissions inspection or testing is a factor.
The key is the line that says "64cc Vortec L31 cast iron straight plug heads". These heads were designed for trucks, and use a unique intake port design and intake bolt pattern. Depending upon what induction you plan on using, the correct manifold will cost you between $175 and $400. If emissions are a factor, you need to do something to make the EGR valve functional since the heads don't have exhaust cross-over passages.
The cam change isn't any big deal, since it uses a common flat tappet design. But, again the heads were designed for trucks, so the valve springs can't handle much more lift than the cam it comes with, so you need to upgrade the valve springs if you change the cam.
Headers just make sense, no matter what else you do or don't do. SLP, Hooker, Hedman, Edelbrock would all work. The exhaust forum has extensive discussions of the relative merits of each. The rest of the system (cat & cat-back) would also provide benefits if upgraded.
Old Feb 7, 2002 | 03:40 PM
dmair5_0's Avatar
Car: 91 Firebird
Just wondering why you'd take a nearly complete 330HP engine and change everything in it?? If you want to add your own cam, heads, etc. buy a short block not a long block.
Old Feb 8, 2002 | 02:50 PM
1991 RS 305's Avatar
Check out Brians web site, he did the swap in his 91 RS. His web page is: http://z28boy.cz28.com/
Old Feb 9, 2002 | 02:41 AM
JPrevost's Avatar
Car: 91 Red Sled
I didn't do that swap
My sig has a parts list of everything you would need to keep TBI.
I also have the step by step to make the swap a 2 day project or a week if you take your time, bs with friends, and forget to order some parts like a waterpump and balancer!
Old Feb 9, 2002 | 10:40 AM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
I'm almost done with my 350 HO swap. Parts I used are in the sig.
Jake_92RS
Jan 28, 2020 10:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
Jlanz55
Aug 17, 2015 07:15 AM
mustangman65_79
Aug 11, 2015 03:17 PM
