motor mounts
Old Feb 24, 2002 | 12:31 AM
moore82nd's Avatar
motor mounts
Are all GM motor mounts for small blocks the same? I have motor mounts of a second gen and im wondering if they will work on my 3rd gen
Old Feb 26, 2002 | 10:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Hmmm, no 2nd gen expert here. But, I'll move you back to the top and say, no, they aren't the same, and let someone throw darts at it.
Old Feb 27, 2002 | 07:13 AM
moore82nd's Avatar
thx for the stab at it im thinking im going to have to just buy all new motor mounts
Old Feb 27, 2002 | 08:42 PM
Cary3982's Avatar
I just found out the hard way that they are definitely not the same. My mounts wouldn't line up, using V8 frame mounts and engine mounts that I found lying around in my garage. I went to Scoggin Dickey yesterday and they had the driver's side mount in stock, but no pass. side mount. I went ahead and purchased the driver's side mount, took it home and compared it to the previous mount that I was trying to use. There is a difference, without a doubt. I can't say for sure that my SBC will drop right in now, as I haven't had a chance to wrench on my car as it's about 8 degrees outside currently. But, I feel confident that the new mount will correct the mount alignment problems that I was encountering.
The engine mounts are roughly $25 each. The local parts stores have the V8 frame mounts in stock for $9 each. I didn't realize this, and paid $25 for salvage yard pieces that I had to pull myself. Another lesson learned!!!!
I hope this helps, and maybe it will save you some of the headaches that I've encountered, thus far, with my V6 to V8 swap. It'll all be well worth it in the long run! :rockon:
Old Feb 27, 2002 | 11:43 PM
moore82nd's Avatar
where would be the best place to by the motor mounts?
Old Feb 28, 2002 | 06:00 PM
Cary3982's Avatar
I bought the engine mount from Scoggin Dickey (local Chevrolet Dealership), and found the frame mounts at both AutoZone & Checker. That should be a good starting place anyway.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
