TPI( 3rd gen) onto an lt1
Old Mar 2, 2002 | 04:25 PM
1iroc2slow4me's Avatar
hey can i put my 87 TPI onto a 97 LT1 block and heads, so i donthave to change the induction and the computer over in my IROC?
Old Mar 2, 2002 | 08:28 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Just have the back of the intake machined for the distributor, make sure you have a 94' up intake, the rest should work fine. :lala:
Old Mar 3, 2002 | 12:46 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
No... he wants to put the TPI on the Lt1 Short Block... To answer your question, yes, it will bolt up. However, I think I have heard of the coolant passages being different. I could be wrong, cause I dont know much about Lt1's. Good luck!
Old Mar 3, 2002 | 03:32 AM
Tas's Avatar
Tas
https://www.thirdgen.org/techbb2/sho...threadid=55974
https://www.thirdgen.org/techbb2/sho...threadid=55958
https://www.thirdgen.org/techbb2/sho...threadid=55879
Old Mar 3, 2002 | 02:17 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
I understood what he wanted to do BUT that would pretty much be a waste of time, all that he would gain is a little better set of heads and slightly better cam, he'd be better off doing heads/cam to his existing engine, the coolant passages shouldnt matter since there are none in the LT1 intake so they wouldnt affect the TPI manifold.
Old Mar 4, 2002 | 05:24 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I woulkd keep the LT1 intake with the LT1 engine. If you'd like to keep the old computer just need to dump the optispark and slap a distributor in there. Of course the intake would need modified for the distributor but it will let you use the old wire harness and ECM.
Old Mar 10, 2002 | 11:31 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
personally i think it'd be a waste of time, you wouldn't really gain that much...
Old Mar 11, 2002 | 01:09 AM
TexasLT1's Avatar
Car: '92 RS
I continue to fail to understand why people insist on strangling and LT1 by putting a TPI on it. whats the friggen point of getting the LT1 then?!
Old Mar 17, 2002 | 10:02 PM
mat89RS's Avatar
if you think money wise, it can be a good thing , however if you're serious about making power, people should carry on the technology that belong to their engine.
Tpi are essentialy made for HO 305, on a mild 350 it would restric the airflow. If you can afford getting larger runner and get the intake manifold ported, why not pay someone to install the LT1 intake for you ?
I can say that right now I'm pretty caked, chill mood you know...chilaxing but seriously stick with the LT1, you'll like it pretty much.
midge54
Dec 27, 2019 04:14 PM
sreZ28
Aug 14, 2015 07:48 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
Sanjay
Aug 12, 2015 03:41 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
