Flywheel Question
Old Mar 6, 2002 | 08:39 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Flywheel Question
I have an 87 Iroc 305 carb(lg4) and i just bought 80-85 recon 350.What i need to know is can i use the fly wheel from my 87 305 or am i gonna have to get a new one.Do the fly wheels have the same teeth
Old Mar 6, 2002 | 08:40 PM
iroc22's Avatar
You'll need to get another probably because the 87 is a 1 piece rear main seal engine while the pre85 motors are 2 piece.
Old Mar 6, 2002 | 09:27 PM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Or do i need a flexplate instead of a flywheel.Need to know ASAP
Thanks..
Old Mar 6, 2002 | 11:24 PM
iroc22's Avatar
Flexplate=auto
Flywheel=manual
Old Mar 7, 2002 | 12:07 AM
87RS402's Avatar
Your going to need a 153 tooth flywheel for an 85 or older SBC. I got mine from a wrecking yard for $65 +$10 shipping.
Thats for a manual trans car, I don't know what size the flexplates are.
Old Mar 7, 2002 | 04:25 AM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Its an auto 700 r4.so is a flexplate different from an 85 to an 87.like i said 80-85 recon motor.
Thank again
Old Mar 7, 2002 | 06:32 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The flex plate would also be different. The bolt pattern on the back of the crank changed in 86.
You need a flex plate from a 83-85 F-body car.
Old Mar 8, 2002 | 09:26 PM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
I called B&M today and they told me i need a 168 tooth flexplate for an 85 305/350 motor.
Old Mar 9, 2002 | 09:05 AM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
IS what B&M told me right?
Old Mar 12, 2002 | 12:16 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
i think w/ the 700R4 its a 153 tooth. Also needs to be for an internaly balanced engine.
Old Mar 12, 2002 | 01:45 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
If you want to re-use your starter, you need a 153 tooth flexplate for an 85 V8 Camaro. That's that. Period.
Why they would recommend a 168 is beyond me. It adds weight and doesn't add performance. Not much weight, but why break it if it ain't fixed? Er... :P
Old Mar 12, 2002 | 08:24 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
You need GM Part# 471529 Flexplate 153 teeth for 2pc. rear main seal.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Trickskier
Aug 29, 2015 01:12 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
