i want a low 12s or high 11s car
Old Mar 21, 2002 | 01:40 AM
Manny's Avatar
Here's the deal:
I got a 95 gen1 2 bolt 350 block that fits a 1pc seal crank. I got the 383-1-SK stroker kit from PowerHouse (www.enginekits.com). I upgraded to CR3 rods with ARP bolts.
I've decided to use T.P.I. and iron Vortec heads.
This engine must pass the NJ emissions laws.
What cam profile should I use? I want her optimal power to be between 4500-5500 rpm.
What intake manifold should I use?
I've got Edlebrock T.E.S. headers with A.I.R. tubes.
I've got a 3 1/2 inch y-pipe, so I think I might go with a Mac cat-back. Should I do this??
What kind of roller rockers should I use?
What can I do with my suspension?
My IROC currently has a built up 700-R4 with 3.23s in the rear end. She needs to have decent gas mileage so these are a must.
To have this motor get me into the 12s range would be perfect, cuz with a bottle I know 11s isn't far away.
Any help would be greatly appreciated.
Old Mar 21, 2002 | 05:34 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You said you was to use TPI and Vortec heads. Now why are you asking what intake manifold to use?
Since you must pass a visual smog then I would use a Superram instead of the TPI intake.
If emmisions wasn't a problem I'd say go with a LT1 intake.
Old Mar 21, 2002 | 09:24 AM
Manny's Avatar
I know there are a couple of intake manifolds out there that support the vortec heads with tpi, but I don't know which is best.
Old Mar 21, 2002 | 10:41 AM
Stroked-Z's Avatar
The TPI wont flow enough for your 383. A stock TPI which is what it seems your referring to that is.
Old Mar 21, 2002 | 11:06 PM
Manny's Avatar
you're absolutely right, a stock tpi setup is not what i had in mind.
c'mon, someone here must have some experience with this....
Old Mar 22, 2002 | 05:35 PM
Manny's Avatar
Found something cool. Check this out........
http://temp.corvetteforum.net/c4/bea...presults.shtml
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Linson
Aug 21, 2015 02:12 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
