Big block in a 3rdgen
Car: 1987 Z28
Transmission: 700-R4
I need some help from anyone thats swapped a big block in a 3rdgen. Im going to be doing this with my project car and basically i need to know everything thats involved in it. Thanks.
i think ill say it before someone else will. SEARCH you will find tons of stuff on swappin in a bbc into our cars. ive also asked this before and it will be alot of work and whatnot. so i guess ur best bet right now is try and search first. good luck
Car: '89 Firebird
Engine: 7.0L
Do a search and see what you can learn from that. I will say that the only significant problem is exhaust. You'll find that most achived messages focus on exhaust.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It all depends on how much you want to do with it. As a daily driver it can be a very simple bolt-in with cast iron exhaust manifolds. Building a 500+ hp engine needs more than just an engine swap.
There are a couple of clearance issues depending on what you use. Things like wiper motors getting in the way of tall valve covers etc.
As everyone else has mentioned so far, do a search in the archive. There has to be at least 100 messages dealing with big block swaps already. We don't like answering the same questions over and over.
Car: 1987 Z28
Originally posted by 88 427 Camaro
There is some info on my page from when I did the swap.
Miles
Miles
Car: 1987 Z28
Yep. Didn't recognize you at first. How is the project going?
Miles
Miles
RyanJB
Sep 14, 2015 03:39 PM
