balancing
Old Apr 1, 2002 | 09:48 PM
Manny's Avatar
balancing
What do I need in order to balance my parts?
I just bought a stroker kit from powerhouse and I have a new block. Just need to have it all balanced?
Old Apr 1, 2002 | 10:28 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
First of all you won't be able to do it yourself unless you have a balance machine and scale.
Everything required for balancing:
Crankshaft
Harmonic balancer and flexplate/flywheel. Since it's an externally balanced engine these parts are required. Buy new ones.
Con rods
Pistons
That's the rotating assembly. It all needs to be weighed. All the weights are adjusted to the lightest part. 8 pistons. 7 heavy ones are reduced to the weight of the lightest one etc. Then the crankshaft assembly is balanced to match the weight of the con rods and pistons.
Old Apr 1, 2002 | 11:20 PM
Manny's Avatar
cool. Does the bottom end need to be assembled or just the parts??
Old Apr 2, 2002 | 08:09 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Take everything unassembled to the machine shop. Once it's all balanced it can be assembled.
Old Apr 3, 2002 | 10:11 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
The balance shop will also want rings and bearings, as their weight is not negligible. At least my shop wanted them.
Old Apr 3, 2002 | 11:02 AM
Muzzs Ro's Avatar
Some kits from powerhouse come internally balanced. Check and see if yours is. I've been looking at engine kits from them myself.
Muzz
Old Apr 3, 2002 | 05:00 PM
johndo1707's Avatar
how much did that kit from powerhouse cost you total? and is your kit for a tpi engine??
Old Apr 4, 2002 | 12:34 AM
Manny's Avatar
In total, the kit cost me about $550 bux with CR3 Rods and ARP bolts AND shipping to New Jersey. The kit is great but is not balanced.
Yes, this kit will work with a TPI engine. I plan on building a TPI 383 motor with an LTR setup and vortec heads.
Old Apr 4, 2002 | 06:32 AM
primo's Avatar
What is included in the kit ?
Old Apr 4, 2002 | 11:24 AM
Manny's Avatar
the bottom end, except for the block. And a complete gasket set and piston rings. Very good kit.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
