Head gasket sealant
Head gasket sealant
Do the head gaskets need sealed? I have heard of folks who don't, and some say to seal with high temp silicone around water jackets and others say to use the Super Yellow "Gorilla Snot" to seal them......what gives? Any suggestions?
Transmission: 4L80E/4L80E
The gasket manufacturer knows best in this case. Follow directions included (if included).
In general, composition gaskets don't need anything. I used FelPro rubber coated steel shim types when I put the 305 back together, they said have a 50 RMS finish on deck & head or use sealant. I sprayed them with aluminum paint, seem to be sealing fine.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Always consult the manufacturer, but a rule of thumb is coated gaskets - no sealer, uncoated - copper spray. "Gorrilla Snot" (weatherstrip adhesive) won't hold up under the heat at the head area.
Dragula,
I see that you have AFR 190 heads, I have the same and the best gasket is Fel-Pro p/n 1010. These do not require any type of sealant. They are about $35 a piece and worth it.
Also pick up some thread sealant from ARP with their bolts. Works like a charm. Also double check your pushrod guideplates with the AFR's. My #1 was put on wrong by AFR, so when I was sealing the rocket studs I flipped it and made sure all the others were correct.
Already got the suckers on. I got the recommended FelPros. Can't remember the number, but they are the ones AFR recommended. I just stuck 'em on and torqued it down (with sealant on the bolts of course). I will seal the studs when I get the pushrods on loosely in order to align the guideplates. I'll send out some pics of the engine maybe tonight. I got the intake and everything on now too.
ambainb
Apr 25, 2016 09:21 PM
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
