Well guys wish me luck, the project begins...
Old Apr 5, 2002 | 11:50 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
In just a few hours (bout 5 to be exact) the L98 will be coming out...
In goes the TTA motor
i have a few people there that know their stuff, Steve(TTA850) will be helping me a lot
WISH ME LUCK!!!!!!!!
Old Apr 5, 2002 | 03:34 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Good luck man! Keep us updated!
Old Apr 5, 2002 | 08:13 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
:rockon:
Old Apr 6, 2002 | 11:46 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
How much did you pay for the motor?
Good luck, and we want pics and numbers when it's finished.
Rob
Old Apr 7, 2002 | 10:48 PM
fly89gta's Avatar
Car: 2018 Camaro SS
ok update!
The motor is ALMOST done! We need a oil pressure sending unit(easy to get) an EGR bracket(not too hard to get) and little things.
We cranked the engine for a split second to make sure there were no fuel leaks, nope! none. All and all things went smoothly, missing a few important things but i was able to get em.
i'll have pics later and i'll work up some prices as well
i got the motor for 2K and i had to get maybe $200 in parts
i'll make up the list later
should be running tomorrow!!!!
Old Apr 8, 2002 | 10:30 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Originally posted by fly89gta
ok update!
This is criminal. I want one I WANT ONE!!!! I don't know what I'm going to do with it but I know I want one.
I think you're going to start a trend with this project of yours
Can't wait for pics.
Rob
Old Apr 14, 2002 | 06:14 PM
polishdevil's Avatar
Car: 88 GTA
Any pics yet???
Dave
Old Apr 14, 2002 | 07:18 PM
fly89gta's Avatar
Car: 2018 Camaro SS
here are some, i think i'm gonna write a tech article of some sort to help guide people, it was a pretty straight forward swap
Swap pics
Old Apr 14, 2002 | 07:52 PM
pardon my idiocy but does the 3.8 use a buick or SBC tranny bolt pattern?
thats really awesome man!!!!!!!!!
it might be something to consider for my 91 V6 once i get my Z28 on the road
Old Apr 14, 2002 | 08:47 PM
fly89gta's Avatar
Car: 2018 Camaro SS
uses a buick bolt pattern, i'm running a 700r4 for now using a TCI adapter plate that allows a chevy bolt patter tranny to bolt to a buick motor
Old Apr 14, 2002 | 08:59 PM
iroc22's Avatar
What motor mounts are you using?
OE driver's side ones are totally obsolete and I was wondering which specialty ones u went with.
Old Apr 14, 2002 | 09:09 PM
89Formula305's Avatar
why a 6 banger?
Old Apr 14, 2002 | 09:26 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Originally posted by 89Formula305
why a 6 banger?
This is no ordinary V6
Old Apr 14, 2002 | 10:29 PM
fly89gta's Avatar
Car: 2018 Camaro SS
the guy i bought the motor off of included the rubber motor mounts and the frame mounts, but they didn't look stock to me, they looked more like Steve Kaminsky's mounts to me..
Old Apr 14, 2002 | 10:31 PM
fly89gta's Avatar
Car: 2018 Camaro SS
why a 6 banger?
Cause a stock TTA motor would smoke any stock L98 out there...i was gonna go wtih a blown 355 or a 383 but why do that when i can get a TTA motor for $2K run mid-low 12's with minor bolt-ons(which is all i really want) and still get over 20 MPG, aren't gonna do that with a blown 355 or a 383
Old Apr 21, 2002 | 03:55 PM
mechanicalmehem's Avatar
TECH ARTIVLE TECH ARTICLE lol this is gonna be hard to explain, i have an '86 camaro that was a 305 carbed but anyway someone else pulled the motor for somethin else(and trans) so me and a couple guys i work with(dealership) have decided to do the 3.8 buick motor with the Le Sabre heads and custom headers(and all components for swap) it'll be long and hard, but hell yea it'll be fun when i get it done(i have to find a good front clip, put the interior back togher, get a trans(T-5, or T56)) anyway, it is a ways off but i'm getting there.
Old Apr 21, 2002 | 05:45 PM
fly89gta's Avatar
Car: 2018 Camaro SS
DO NOT, i repeat, DO NOT go with a manual trans with a turbo 3.8, you will be SOOOOOOOOOOOOOOOOOOOOOOOOO sorry
These motors are not high revvers like your import turbo motors. The power stops at around 5000-5200 much like a TPI motor. These engines require load to build boost, as soon as you let off the gas and push the clutch bye bye boost. Also it will be tough to build boost at the line.
Much research has been done on this, do yourself a HUGE favor...get a nicely built 200-4r with a 10'' converter, the results will be MUCH better
Just an FYI you don't NEED to change the heads unless u are retaining AC. Also make sure u change the pistons if u do the LeSabre heads or else you'll be sitting at around 9.0:1 compression...
9.0:1 and 16+ lbs of boost=fried head gasket or worse....
EDIT: Also if u keep the GN heads you can use the GN headers and x-over pipe(a relatively cheap find) but would need to have a custom downpipe made.
Old Apr 22, 2002 | 05:38 PM
iroc22's Avatar
Good point about the boost.
Cleotiz
Jan 6, 2018 08:56 PM
beast94
Aug 20, 2015 06:44 AM
Street Lethal
Aug 14, 2015 08:25 PM
bryan623
Aug 10, 2015 11:33 AM
