ever seen this
Old Apr 19, 2002 | 05:33 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
ever seen this
[IMG]C:\My Documents\My Pictures\exhaust on 82 se.jpg[/IMG]
have u guys ever seen anything liek this it was on an 82 se
Old Apr 19, 2002 | 07:43 PM
Tas's Avatar
Tas
erum.... you have to attach the picture, you can't link it directly from your computer.
Old Apr 19, 2002 | 11:15 PM
Car: 89 Formula
Engine: Carbed 5.7
there ya go
Old Apr 19, 2002 | 11:18 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
That's different, but where does the I-Pipe connect to? Is it duals, if not, why is there 2 mufflers?
Old Apr 20, 2002 | 12:08 AM
jeffs82z28's Avatar
The 1982 V-8 cars had that exhaust system. I think some 83's had it also.
The system routes the same as the other f-bodies do.
Mine has a 2.5" cross over,but where the bends are it wrinkles, into a catalytic converter on the left side, then a 2.25 intermediate pipe to just in front of the rear axle, then Y's into a pair of 1.75" tubes that are pretty much parallel over the axle and into the 2.25" resonator between the two mufflers, then out through 2.25" tail pipes.
It does have some drawbacks though:
1. The crossover isn't mandrel bent, and it does that T thing on the left side.
2. The Cat needs better flow. (what factory cat couldn't use more flow?)
3. The I pipe should be larger. 2.5" minimum.
4. The over axle Y-pipe should be 2"
5. The resonator should probably be larger.
6. The mufflers have 1.75" inlet and outlet. Way too small.
Sorry it's so long but you asked
Old Apr 20, 2002 | 12:29 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Yup, got changed to 1 regular dual outlet muffler in 84.
Old Apr 20, 2002 | 01:47 AM
EvilCartman's Avatar
Car: '82 Z28
I had all that crap ripped out from my car as soon as I could afford it. After doing that, my new exhaust made a big difference
Old Apr 20, 2002 | 01:52 AM
HrdRockA4305's Avatar
That just looks like "the hard way" to me. I guess they didn't have much for cross flow mufflers yet at the time, I dunno.
