How do I get the passenger side header in?!? HELP
Old Apr 21, 2002 | 03:16 PM
TBI305Camaro's Avatar
ok i got the driver side on no problem but now the pass side will not go not from the bottom or top i have hooker shorties...it will almost go in from the top but the black box is holding it back...i took out the plugs and the fan switch (antifreeze is everywhere) hoping to get the clearance but it didnt...ive also been trying to jack the motor up but it refuses to go it tries to take the whole car...i took out the pass side motor mount bolt out but it wont pivot like i hear it does...what should i do now? i even took out the starter in hopes of getting clearance...could i remove the black box?? HELP PLEASE
Old Apr 21, 2002 | 03:25 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I think it is the perfect time to take out the black box, just fab up some sheet metal to cover the hole in the firewall, this will make changing your plugs so much easier too.
Old Apr 21, 2002 | 04:58 PM
jesse83cfi's Avatar
no leave the black box in damnit!!!
ok hear is what u got to do. i just did this to my car last week, im telling u that u dont have to remove that black box. i got an 83 ta and im sure u have the same clearance as i do. first take off the dust cover off the flywheel then take out the starter. then remove the spark plugs, remove the air pump pump if u already haven't. ok now this is the hard part but it can be done, this part took me 30 minutes to wiggle it in the right place, ok put the collector at the front of the motor and slide it back, now u just got to wiggle it around until u find the sweet spot and then it will slide in perfect, but i warn u once u get it in u have about 1/2 inch of clearance from ur tranny and ur frame! hope i might have helped but dont remove the box!
jesse
Old Apr 21, 2002 | 07:31 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
i have the edelbrock tes headers and my drivers side poped right in place but i was havin a hard time with the pass. also and my dad came over ripped out the dipstick and it slid right in. well i have the valve cover and that think that bolts into the A.I.R pump with the long black pipe. you'll see it. good luck
Old Apr 21, 2002 | 11:20 PM
ripped out the dipstick?!? anyways my starter plugs and everything are already out of the way she slids almost all the way down but i dont have the clearance because of the black box...i have no air injection or any of that crap left...why not take out the black box?? i dont have AC anymore so i dont need it
Old Apr 22, 2002 | 08:19 AM
Car: 99 Formula
Axle/Gears: 342
Man, chill out guys, I didn't say you had to remove the box, but man, it will clear up a lot of clutter, make changing the plugs a lot easier and will really improve the appearance of the engine bay. That's what I plan on doing sometime.
Old Apr 22, 2002 | 12:17 PM
Bulldog92's Avatar
Car: '92 Camaro RS
Engine: 350 H.O.
Axle/Gears: 3.73 posi
I just put in some SLP shortie headers last weekend, but they weren't Hookers so I don't know if this applies to you. Anyway, I had to unbolt the air compressor and set it to the side as well as bend the crap out of my dipstick to get my passenger side header to go in. I would assume that you don't have a compressor anymore since you're not running air conditioning, though. Mine just practically fell in when I did those two things. I did have a couple of fatalities, though... had to get a new fan switch (broke it) and still need to get a new dipstick & tube (already mentioned...they dont' bend back too well ). Just thought I'd throw in my $.02.
Old Apr 22, 2002 | 12:24 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Why bend the dipstick? Mine's only held in with 1 bolt and it just slips into the block, give it a little tug and it comes right out.
The only issues I had putting in my passenger's side SLP was the dipstick and the coolant hardline for the heater. I already ripped my A/C out, which made it a *hell* of a lot easier.
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Wesly_66
Aug 26, 2015 09:55 PM
Cameeeero
Aug 20, 2015 03:06 AM
Street Lethal
Aug 14, 2015 08:25 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
