Rerouting Exhaust????
Old Apr 22, 2002 | 10:47 PM
SlowStangEater's Avatar
Is it a pain to reroute exhaust so its on the opposite side of my starter? Im tired of dealing with heat soak issues.
Old Apr 23, 2002 | 12:06 AM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
Not sure if you can do that. But I am thinking no. Something to look into is a high tourque starter. They are pricey, but they are half the size and weigh so with that and a heat sheild that should all but eliminate the problem.
Old Apr 23, 2002 | 12:08 AM
I figured not. Im looking into a high torque starter but I want to try a remoter solenoid first. Do you know anything about those. Im not quite sure how it would work but I think I get the concept.
Old Apr 23, 2002 | 12:13 AM
88Bravo's Avatar
I know a buddy of mine did it on his 70 goat. But out side of that I am lost. Have you tried any kid of heat shields or wraps? I am thinking about going with headers myself and I would like not to have this problem.
Old Apr 23, 2002 | 12:16 AM
Actually I have 2 heat shields on the damn thing and it still wont start when it gets hot. Im mystified as to why it still does it. And the worst thing is that I dont even have headers!!! I have a 89 305 5 spd and thats the only major problem. Its starting to get to me. when it gets hot it wont even click or anything. I can either jump start it or wait a while and then it will start. I dont get it?????
Old Apr 23, 2002 | 12:24 AM
88Bravo's Avatar
Like my sig says, I have a 88 5 speed bird. It sounds like to me that it is more than a heat problem. If you can jump it, when it is hot, it sounds like a power problem. Is the batterie still good? What aobut the connections to the starter its self. loose, dirty, crappy wires, things like that. But you may still be right about a heat problem, I just know our cars are alot alike in that aspect and I don't have any probelms with my starter. How old is your starter and where did you get it?
Old Apr 23, 2002 | 01:58 AM
MelloYello's Avatar
Most likely its your starter solenoid and not the starter itself that is the problem....get a remote mount soleniod kit from Summit for $25 and your problem will be solved.
Old Apr 23, 2002 | 02:12 AM
88Bravo's Avatar
How hard are they to install, and will it solve the problem with header heat?
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
david068513
Sep 18, 2015 10:36 AM
gta892000
Sep 16, 2015 12:37 AM
