replacement tail pipes?
Old Apr 23, 2002 | 02:33 PM
brian89transam's Avatar
I have a very old dynamax cat-back system on now. The muffler is rusted so bad that one of the tailpipes came out. The intermediate pipe is in great shape though, I'm pretty sure it's a 3" too. I want to order a replacement Hooker Aerochamber muffler but I'll need tailpipes too. Anyone know where I can get pipes? I've heard you can order dynamax pipes piece by piece, but i don't know how or where. I'll also get tips from somewhere too.
Also, anyone know if I can get a Hooker replacement muffler that has a 3" inlet and dual 3" outlets? then I could use 3" tailpipes.
Thanks a lot. I don't wanna spend $260 on a catback when i already have the intermediate pipe, especially when the muffler is only $75. Thanks again.
Old Apr 23, 2002 | 02:40 PM
Tas's Avatar
Tas
call summit, if they don't know the part numbers offhand they can give you dynomax's telephone number so you can call them.
www.summitracing.com
Old Apr 23, 2002 | 02:57 PM
Marshall89ws6's Avatar
u can have a local muffler shop make you pipes.... for cheap and good ones too
Old Apr 23, 2002 | 03:29 PM
Yeah but they wouldn't be mandrel bent then.
If I get Dynamax will I have to cut the turn down ends off to put on tips?
Old Apr 26, 2002 | 12:40 AM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
YOU CAN BUY MANDREL BENT PIPES ANYWHERE YOU JUST HAVE TO ASK. MANY MANUFACTURES ARE MANDRAL BEND EVEN THE CHEAP JC WHITNEY CAT BACK SYS WHICH IS MADE BY PACE SETTER. SHOP AROUND YOU WILL BE SUPPRISED ON WHAT YOU FIND AT LOWER PRICES.
Old Apr 26, 2002 | 12:14 PM
Matt86Z's Avatar
IMO, I'd say that mandrel bends on dual outlets are redundant anyway. The flow of exhaust exiting a crossflow-type muffler is so outta whack allready, there's not a whole lot of advantage to paying extra for mandrel bends in the last 36"...
Old Apr 26, 2002 | 05:24 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
precisely just get the 3" muffler and have the exhaust shop weld it on with tailpipes
Old Apr 26, 2002 | 06:24 PM
primer84z's Avatar
so your saying a 3 inch catback that isnt mandrel bent wont make a difference? if thats true ill just buy the aerochamber crossflow muffler and get a shop to weld up a catback. i dont have any pipes going out the back now just a homemade ****ty ypipe into a flowmaster 40 series right where the cat should be. how much will it cost to install a muffler and make new pipes to go to it?
Old Apr 28, 2002 | 10:58 PM
depending on the shop they might not do the work if you do not have a cat. but i would expect to pay anywhere between 125 to 250 for the pipe bending and welding from the ypipe all the way to the muffler then tailpipes
Old Apr 29, 2002 | 02:58 AM
cort351w's Avatar
Dr. Gas sells f-body tail pipes. For some reason they are in the NASCAR section at www.drgas.com.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
Out-Cast
Aug 22, 2015 07:49 PM
