2.75" true dual exhaust
Old May 23, 2002 | 10:27 PM
5L EaTeR's Avatar
putting all new exhaust on the iroc. i am determined to do true dual exhaust (please dont tell me that a single pipe is better...im not here to debate and ive already made up my mind) but was wondering on size. wil dual 2.75" pipes fit? already have coated hooker super comps and was thinking of doing flows 40 series mufflers. whats the largest diameter TRUE dual exhaust system that will fit on an 89 iroc? any info would be great, thanks
Damien
Old May 23, 2002 | 10:43 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I don't see why not, except if you want it to exit the rear, then it might be kind of tight.
I still don't see how anyone can argue about duals.
Old May 23, 2002 | 11:20 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
i have seen in person a formula with hooker SC/LT and 3 inch true duals with 40 series flows. I am going to run 2.5 because of noise. The guy said that he didnt have any ground clearance issues and even had a h pipe, it looked real good, it was ran down the driveshaft tunnel, and the flows were under the back seats, he said he beat them up 3 or 4 inchs. I am planning on running the same setup if i ever get my darn engine together. hope this helps. jason
Old May 25, 2002 | 02:54 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
I am running 3" duals from the headers back to (2) 1-chamber mufflers.But I am also having clearance issues since my car sits almost 2-1/4" lower than stock. All depends on how you route the pipes.
Old May 26, 2002 | 11:10 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
niether do i
i would just go ahead and do 3" true duals instead of 2.75"
Old May 27, 2002 | 12:17 AM
LilJayV10's Avatar
Engine: 406 Roller
hey RS speed, how do you have your pipes ran? hows the lowered car with long tubes and true duals working out?
Old May 27, 2002 | 02:55 PM
RSpeed's Avatar
The pipes are ran straight back and end right before the rear axle with 1-chamber Flows. The real clearance issue is actually with the longtubes rather than the rest of the exhaust.The only bend in the pipes is at the tranny xmember where the pipes are bent slightly upward after it clears the crossmember. With the car being lowered like it is,my collectors have kissed the ground a few times. Lowered car and duals on a non dual car-sacrifices,sacrifices.
Old May 27, 2002 | 03:17 PM
LilJayV10's Avatar
Engine: 406 Roller
how much is it lowered? I thought about getting the eibach kit that lowers it 1.5-2 inches, i think its the sport kit, but didnt know ho it would work. thanks for your reply. jason
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
Camaro_383
Sep 11, 2015 11:28 PM
Djmathis123
Sep 8, 2015 08:42 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
