Hollowing out a cat.
Old Jun 19, 2002 | 11:46 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
My Catalytic converter is bad so I am going to hollow it out until inspection time comes around in a year and a half or so. What is the Outer Diameter size of a pipe that will fit inside the Catalytic converter? What I am asking is what is the Inner Diameter size of the Catalytic converter so I can put a pipe inside cat.
My car is an 89 Iroc 350
Old Jun 19, 2002 | 05:01 PM
turtle's Avatar
you could just pound the guts out and leave it as is but it should be slightly smaller then 3 in.
3 in outer diameter cat = ? inner diameter.
Old Jun 19, 2002 | 06:20 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
just measure your y-pipe, the cat's "neck" was a slip fit over the y-pipe, there for the same size pipe should fit on the inside, of course I'm guessing about true fit (rust and stuff), I ended up cuttin mine off and up a pipe in instead
Old Jun 19, 2002 | 09:00 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
I would just pull all the ceramic and what not out the cat and leave it hollow with no pipe. Will be the easiest thing to do until you can get a new one.
Old Jun 19, 2002 | 10:08 PM
85zcamaro's Avatar
Well this may be a dumb question.... but i have a 85 z28, what would i have to do to gut my cat since it also is going bad? If it's simply pulling out stuff, i've heard that the stuff inside is toxic, what should i do to take it out or keep from harming myself haha. Im just a kid trying to learn amap sso any help would be aprreciated
Old Jun 19, 2002 | 10:15 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
85 z
I wouldn't worry about it too much I did mine about a year ago, I have a foot long drill bit, and some smashing goodies (pry bars, etc) after you mash and mash you I started the car up or sometimes used a shop vac to blow/suck the honey comb out.
as long as you don't eat the crap you'll be fine, I'll still alive, no side effects , but I'm still 19
Old Jun 19, 2002 | 10:50 PM
trans87's Avatar
Don't worry it's not toxic. It's not like abestos or something. Just get some good prying tools and mash the comb real good then try a coat hanger or something and pull it all out. Just don't eat what comes out and wash your hands when you are done
Old Jun 20, 2002 | 12:54 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
So if I am about to purchase a new high flo cat should I gut it also to get that throaty sound or not? Will gutting the high flo allow me to pass the Illinois Emmisions test?
What cat should I buy? I have a LG4 4bbl Quadrojet with a Flowmaster 80 series.
Old Jun 20, 2002 | 01:15 AM
trans87's Avatar
There would be no point in getting a hi-flo if you are going to gut it. Just gut your stock one and save money. But gutting a cat will make it fail smog. Yes a hi-flo gives you a nice throaty sound. I know mine made me louder
Old Jun 21, 2002 | 06:21 PM
StangKiller's Avatar
Just so you will know, a gutted cat will give your car a crappy tinny sound, I know because I had one for a short time, then I had a buddy at a muffler shop weld in a straight pipe to replace the gutted cat, you would not believe how much better it sounds with a straight pipe there!!!
Old Jun 21, 2002 | 07:37 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I had my straight pipes made yesterday, if you're going to gut it, put a pipe in it. It sounds *much* better.
Old Jun 21, 2002 | 08:47 PM
Audiman's Avatar
you can get a replacement cat at Napa for about $100.00
Old Jun 22, 2002 | 05:41 PM
uk89camaro's Avatar
Angle grind a rectangle section out of the bottom of the cat box, drop all the crap out, and weld the section back in. (You can leave the cat sensor tube thingy as is). I cut off the rear baffle box, and had a straight single pipe exit from the centre rear.
Sounds good to me. (And not at all *******!)
I can e-mail the sound file.
Old Jan 7, 2007 | 10:01 PM
Pyrice4's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1L V6
Transmission: M5
Im going to try to put a straight pipe through the middle of my cat. It hollowed itself out on its own. We dont have emissions tests in Florida.
Old Jan 7, 2007 | 11:32 PM
88camaroTBI's Avatar
anyone ever have straight pipe rigged up at a muffler shop? with the flanges and all? if so how much, if not...estimate? thanks
Old Jan 7, 2007 | 11:54 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
thats what we did, my buddies dad cut the flanges off my cat and welded it to my pipe. completely bolt in. made the 'ol LG4 sound a good bit more throaty, more defined. wished i coulda put some headers on that thing...
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
92firebirdguy
Sep 1, 2016 07:53 AM
deracer
Apr 11, 2016 12:04 AM
ProtoMaster22
Aug 26, 2015 07:50 AM
Chvywolf
Feb 9, 2001 06:24 PM
