How much of a problem would this be?
Old Jun 27, 2002 | 03:54 PM
The Greek's Avatar
Car: 70 Nova SS
Transmission: TH350
If I install this pipe found here http://www.macperformance.com/macsto...o/cmrohdr.html (all the way at the bottom) is it going to be permanent or will I be able to swap it in and out with the cat for emission testing. What is the best solution in order to have the most flow without running into emission problems, I am thinking a high flo cat but those are a little pricey. Any suggestions are greatly appreciated.
Old Jun 27, 2002 | 04:52 PM
89BlueTA's Avatar
As long as you just clamped it on, you could probably just switch it out. But I doubt that you would be able to get your original CAT out without damaging it.
nick
Old Jun 29, 2002 | 11:44 PM
89Irocz23's Avatar
it would be fine, but there is no way in hell I would pay that much when i got mine custom made at a muffler shop for 20
Old Jun 30, 2002 | 12:14 AM
Tas's Avatar
Tas
it would be cheaper to get a used 3" catco and put a 3" pipe through it.
Old Jun 30, 2002 | 01:06 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
hell it would be cheaper to get a new catco and put a pipe through it or take off the shields and weld them to a pipe(what i did). that is if it was a universal catco
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
