what spark plug wires are you guys using w/ your headers?
Old Jul 4, 2002 | 08:37 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
i need some wires that can take the heat of my new headers. Three of the boots on my accel wires squished out between my fingers when i went to take them off. Not pritty. What wires work for the rest of you? I have edel. tes headers and they get pretty close to the boots so ill try to see if i can find shorter plugs or soemthing.
Old Jul 4, 2002 | 09:23 PM
iroc22's Avatar
180* Taylors work very well for me. I've never burned up Taylors on headers before.
Old Jul 4, 2002 | 09:36 PM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
my msds have burnt up on me yet.
Old Jul 4, 2002 | 10:39 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
8mm Accels, next time MSD though. I also have heat sleeving on them, wire looms (a must), and MSD wire separators.
After burning 3 wires I learned my lesson.
Old Jul 4, 2002 | 11:00 PM
Car: 88 Camaro SC
Engine: SFI'd 350
i have looms and everything but the radiant heat coming off the primaries parked in front of the boots was enough to reduce them to goo.
Old Jul 5, 2002 | 03:54 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Whats in my sig has worked for a long time with no problems. I don't use wire looms so the are not a must, but if you use them they will definitely look nice. Coated headers will help.
Old Jul 5, 2002 | 10:05 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I use Jacobs 8.5m wires. Work great for me and have a lifetime warranty.
Old Jul 5, 2002 | 11:22 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i use msd wires with heat sleeves and so far no problems.. i do have some wire looms to put in eventually..
Old Jul 5, 2002 | 03:29 PM
Tas's Avatar
Tas
msd 8mm with 90* boots. 2 days now with headers, no burns.
Old Jul 5, 2002 | 10:58 PM
Car: 88 Camaro SC
Engine: SFI'd 350
i replacedt eh damaged boots and used soem ez-foil disposible bake pans to make heat sheilding around the boots and wires. The boots seem to be at a much lower temp. After i shut the engine down i could touch the boots w/o getting burned. Pretty getto, but it seems to be working.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Thaney9
Oct 24, 2015 07:26 PM
Thaney9
Oct 15, 2015 06:37 AM
meeklay812
Oct 1, 2015 03:46 PM
