Ok who's got long tubes?
Old Jul 6, 2002 | 10:33 PM
Timmys88Z's Avatar
I need to find out if there are any problems installing and running long tube headers on our cars...
It's a 350 TPI with A/C and all the stock emissions **** on there still.
Anything I need to know? Any particular brands that fit or don't fit?
I just assumed on getting Hooker Super Comp's
Old Jul 6, 2002 | 10:59 PM
Tas's Avatar
Tas
um they're not CA legal you know. Why not get 1-3/4 SLPs?
Old Jul 7, 2002 | 02:13 AM
Timmys88Z's Avatar
yes I know.
Anyone?
Old Jul 7, 2002 | 02:31 AM
IROCFAST's Avatar
Timmy, they are somewhat of a bitch to put on, but do work very well. They work best coming in from the bottom, so if you have access to a lift, it makes life much easier. Also, as I'm sure you know, you will have to have a Y-pipe made. They can be a major bastard to put on, but stick with it and you will get them.
Old Jul 7, 2002 | 02:47 AM
Timmys88Z's Avatar
cool. what headers do you have?
Old Jul 7, 2002 | 10:31 AM
highhat's Avatar
i do
Here's a link to my thread about installing long tubes n duals I just started the install so keep checkin back for updates
https://www.thirdgen.org/techbb2/sho...hreadid=106154
Old Jul 9, 2002 | 12:42 PM
Timmys88Z's Avatar
I know theres people out their running long tubes.....
help please.
Old Jul 9, 2002 | 08:24 PM
Fast3rdGen's Avatar
i got the hooker long tubes. they rock. hope your car isn't lowered......mine isn't and the collectors hang pretty low. they absolutley have to go in from the bottom. and if you want to keep the emissions crap you'll need to find a way to fabricate and install AIR tubes and you'll have to weld an o2 sensor bung in place. soon as i got my car passed e-check i put mine on with dual exhaust and flowmasters. got two more years of fun till next e-check then the edelcrap headers with a cat and cat-back go back on.
Old Jul 9, 2002 | 10:01 PM
Momar's Avatar
Do you know how many inches clearance you have on your collectors? I just ordered mine a couple of days ago. I ordered the hookers directly from jet hot. Here is a link to a guy with the hooker lts and the mufflex y pipe. http://www.geocities.com/cfrios/Phil87IROC.html
Ben
Old Jul 9, 2002 | 10:08 PM
highhat's Avatar
hedmans
Hedmans don't hang as low and aren't as long. but i'm having minor probs installing them. also the myth about having to mod the firewall is false with the auto tranny
Timmys88Z's Avatar
well I plan on running duals and so i dont imagine they'd hang lower than the mufflers...?
My main question is, is there enough room in the stock engine bay to fit them? Or do I have to remove things.....a/c, emissions.....etc?
Old Jul 9, 2002 | 10:15 PM
highhat's Avatar
install
For my hedmans the drivers side going in from the top
Removed both stock exhaust manifolds
Removed winshield wiper motor
Removed bolt from drivers side motor mount
Jacked up drivers side of motor as far as I could
then they dropped right in!
Passenger side is still waiting rained today
Old Jul 12, 2002 | 03:31 PM
Timmys88Z's Avatar
I thought more people were running long tubes....
I want to order some headers.
Anyone know if Hooker Super Comps will fit w/o having to remove stuff?
Old Jul 12, 2002 | 03:41 PM
Momar's Avatar
I dont think you have to remove anything, although I am getting rid of some stuff anyway. I have heard that with serpintine setups, one of your brackets that mounts to the exhaust manifolds will need a custom spacer made so that it will still mount out as far as it did on the manifolt thought. I cant remember what it was though. Oh, and by the way, mine just showed up.
Ben
Old Jul 12, 2002 | 03:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"Not legal" isn't a problem for you?
Old Jul 12, 2002 | 04:08 PM
Timmys88Z's Avatar
I plan on registering it in Nevada (Mom is moving) before the next emissions test...
Old Jul 12, 2002 | 04:15 PM
Fast3rdGen's Avatar
hey where i live there is no underhood inspection.....all they do is stick a mirror under the car to look for a cat. so long as your car passes the sniffer test they don't care what you got under the hood......and yes the very motor in my sig fast passed e-check with no carb adjustments. just had edelbroke headers, new cat, and a flowmaster cat-back. ya shoulda seen the look on those young guys faces as they were arguing who was gunna test my car lol. it sounded like a nascar when i pulled it into the garage lmao :rockon:
Old Jul 13, 2002 | 03:11 AM
Timmys88Z's Avatar
ooops
Old Jul 13, 2002 | 04:54 PM
5.7lformula's Avatar
I have headmen LTs. I love them. If i remember right we put them in from the bottom. We had to pull the starter to install them but that was it. I have a custom y-pipe. I need a new one that hangs just a LITTLE bit lower. The current one bangs on the bottom of the car. Other then the exhaust leaks that im to busy to fix it works and sounds great. I yanked all the emissions crap and still have a/c if that helps any.
Jesse
Old Jul 20, 2002 | 08:26 PM
Timmys88Z's Avatar
Old Jul 20, 2002 | 09:45 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I've had both the hooker and hedman full length headers. I'm using the hedman full lengths right now, I orginally bought the hookers for my current set up but I wasn't happy with how they fit so I ended up not using them. I've heard that the Hookers fit well on some peoples thirdgens but on mine they didn't fit well at all so I got the hedmans. I did a review of the hooker LT vs the Hedman LT headers on the aftermarket product review board a few months ago so you might want to do a search for the specifics.
Old Jul 21, 2002 | 12:18 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
re:
I just dropped my L98 in today. Motor(305)/tranny(6-spd) were both out. I had a chain around the back of the a-arms to support the rear of the motor when we pulled the tranny out. The chain worked well to support the collectors when I had them laying across the k-member and it. Then I slowly lowered the motor in and then bolted them up when I could. I'm pretty sure they are 1-5/8" w/ 3" collector Headmans. I traded shortied for these from a buddy. I do NOT have a cat or AIR anymore, but do have AC. I don't think LTs will interfere with any of this stuff if you need to keep it all. BTW, I still have to weld an 02 bung in. Hope this helps you or someon. Later Now I gotta make a y-pipe with dump chutes on it
Old Jul 21, 2002 | 10:28 AM
highhat's Avatar
RE
Did you have any clearance issues with your hedman LT's?
Mine are hitting what I think is the A arm if motor mounts don't fix the prob then i'm gonna notch the a arms
Old Jul 21, 2002 | 01:59 PM
jbenge's Avatar
I had to make a small dent on the passenger side header to clear the A-arm on that side. The header would go on without denting it but I was worried about rattles so I went ahead and dented it. Other than that they fit perfect.
Also if you are having major clearance problems check the part numbers on your motor mounts if you have had them off or have changed engines. I had mine switched at one point after swapping engines and they are just different enough to cause major interferance problems with headers.
Old Jul 21, 2002 | 03:51 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
Who has Long Tubes with a manual tranny? Do they clear the clutch hydraulics? How well does the exhaust clear the tranny crossmember and how much ground clearance is there?
Old Jul 21, 2002 | 07:55 PM
Momar's Avatar
I posted this link earlier in the thread. He has a manual, but it may be aftermarket. His name on the boards is Phil87Iroc.
Ben
z 28 jari
Sep 14, 2021 10:03 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
cstrobel65
Sep 16, 2015 11:54 AM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
