true dual guys enter here...
Old Jul 18, 2002 | 06:23 PM
InTeRcEpToR5.7l's Avatar
post pics of what it looks like or describe it if you can, i am thinking of it...what muffler(s) what size pipes? lets hear the thunder!!
Old Jul 18, 2002 | 08:39 PM
VampireHunterC's Avatar
Well, I currently have Hedman Hedders and collectors/reducers. After the reducers, it is flex-pipe all the way down the car and over the back axle, with the glasspacks just under the rear bumper, and dual-style exhaust tips clamped on the mufflers. Unfortunatly, it looks like what it is: a shadetree mechanic exhaust job. We ran out of hangars, so the driver's side hangs low and scrapes over bumps, and the flex-pipe is already rusted. After I replace the starter and water pump, I am going to put in some copper gaskets (to hopefully get rid of the damn leaks) and run some "real" straight pipes. Not sure how I am going to get over the axle without using flex pipe, though. I don't know if the pre-bent stuff from the parts store will fit over the axle. It sounds bad-***, though. True muscle-car sound.
Old Jul 18, 2002 | 08:55 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
hey vampire hunter i doubt the copper gaskets will get rid of your leaks that flex pipe leaks like a siv so i doubt u will get rid of your leaks.
Old Jul 18, 2002 | 09:24 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I have yet to see a decent set of duels on a thirdgen. There is a pic of a good looking set of duels with a X pipe on a fourth gen on this site but it would not work on our cars because of our transmissions cross member. I wish there was a way to do it, because if there was I would do the same; but I still have not seen it. So by all means if anyone has pics of system that will give the car the same ground clearance as a single system (which is is barely enough) please post them here.
Old Jul 18, 2002 | 09:25 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I forget whos exhaust this is but I like it. Once I get the car running again with the new heads/cam I'm going dual 2 1/2" and I'm going to try to copy this guys
Old Jul 18, 2002 | 09:31 PM
Car: '89 IROC-Z
shot of the H-pipe.
Old Jul 18, 2002 | 09:33 PM
Car: '89 IROC-Z
Also check out this link
http://www.y-t-g.com/exhaust.html
dual 2.5" exhaust
Old Jul 19, 2002 | 03:17 PM
Fast3rdGen's Avatar
that is almost identicle to the dual set-up on my car.
Old Jul 19, 2002 | 04:57 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
"ground clearance? What is ground clearance? I do not know of this term" said the guy with dual exaust, but its probably worth it.
Old Jul 22, 2002 | 08:19 AM
Which would be why the flex-pipe is going to be 86'd in favor of actual piping, probably from the parts store to begin with.
MustangBeater20
Oct 29, 2022 09:20 PM
onefreakz
May 14, 2018 12:15 PM
okfoz
Mar 9, 2017 02:35 PM
Street Lethal
Aug 14, 2015 08:25 PM
