Exhaust help!
Old Aug 20, 2002 | 02:45 AM
JoshZ28's Avatar
Exhaust help!
Hey guys, i'm new to the forum. I just baught my 1st camaro last weekend, its an 84' Z28 5.0 H.O w/ a 4bbl carb. It's in pretty good condition, the motor runs strong and is clean, interior is completely intact & clean and looks good except for drivers seat, it's ripped. I picked it up for $700. I just couldn't pass it up. As far as I can tell it has a stock exhaust setup on it, the guy said it has hooker headers, and they have a small leak, we just had a catalytic convertor put on it, because it was without one, what I want to know is, what are your recommendations for a good but cheap exhaust system, I don't know if I should just put new hedders and then some flowmaster & tips or should I re-do the pipes completely, and how complicated would that be, please give me some suggestions and what kind of work would be required. Thanks.
Old Aug 20, 2002 | 08:36 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Don't buy headers if you already have them. I'd say look into the Hooker cat-back, which is 3" on back. But if you're set on Flows get that. There is a sound clip in my sig.
Welcome by the way.
Old Aug 20, 2002 | 10:28 PM
JoshZ28's Avatar
Thanks man, I listened to your clip of the hooker cat-back and I love the way it sounds, do you know where I could buy it from and about how much do you think it'll cost? Also, do you think i'd get a similar sound on my pretty much stock 305?
Old Aug 20, 2002 | 11:06 PM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
Cost for yours, I think $200, may be in stock, may not. Check Summit and Jeg's. Mine were $259 but they are a different model and I got the last set from Summit and the are on Backorder now.
hooker catback, BTW.
Old Aug 21, 2002 | 12:47 AM
Car: 99 Formula
Axle/Gears: 342
Car: 99 Formula
Axle/Gears: 342
It will be $200-$260 depending on your app. Only difference is the way they connect to the cat. The $200 one has a square flange hook up to the cat.
It will sound similar to my 1st clip, cause that is on an 8.5":1 compressoin motor, and a worse cam than yours. And a non hi flo cat.
Old Aug 21, 2002 | 01:14 AM
JoshZ28's Avatar
is that the 350hooker.wav file? or is there a different one?
Old Aug 21, 2002 | 08:05 AM
Car: 99 Formula
Axle/Gears: 342
That's the sound from before the cam/intake/gear drive mods.
But for somereason my hookerCOMPxe file isnt' showing up, I'll get it hosted soon.
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
