HP Gains
Old Oct 1, 2002 | 01:01 AM
Darkhawks86T/A's Avatar
HP Gains
What would the apx. HP gains from Edelbrock Headers/ Y Pipe, Hi flow Cat with a 3" Custom Cat back pipe into a 80 Sieries Flow?
This is in a 86 T/A with the LG4 Engine pretty much everything stock cept the K&N and L69 intake housing.
Old Oct 1, 2002 | 07:45 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd say you're looking at a 25-30hp gain at most.
Old Oct 1, 2002 | 11:42 AM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
yeah, about 30 hp. stock LG4 exhaust systems are horrible. its gonig to be a very noticable difference....
Old Oct 3, 2002 | 03:55 AM
Heh i was hoping near 40Hp... I read somewhere in Jegs, that just the 80 seriers flow for Camaro's and Firebird's add 30Hp and 40Tq. (At the Flywheel) and that the headers add 22Hp to the ground. This should drop 1/4 Et by around .5 sec atleast right??
Old Oct 3, 2002 | 07:40 AM
slow305's Avatar
Car: 1982 Z28
Engine: LC9
Transmission: AR5
I wouldn't believe all the propaganda that a manufacturer or retailer claims. They're trying to take your $$$ and hope you believe everything you read.
You know, K&N air filters are good for 40 HP on some applications.
Old Oct 3, 2002 | 10:10 AM
Car: 99 Formula
Axle/Gears: 342
Oh man, you've been suckered in like all the other 17yr old Mustang owners.
All kidding aside, yes , they say "UP TO 40HP". This means if you throw it on a 502 BB that is producing 500 hp, yeah you take a ****ty stock muffler and replace it with the flow, you're goin to pick up quite a bit of HP.
But throw that flow on a 170 hp and you're not goin to get 40hp.
Old Oct 3, 2002 | 01:03 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
It may actually give you 40hp on the LG4, depending on the size of the cat (it has to be a 3" to make any sort of power.
Now a full exhaust, intake, air cleaner, and timing computer adds up to about 225hp on an LG4, so 190 with just an exhuast is possible.
Old Oct 3, 2002 | 02:08 PM
Momar's Avatar
You mean gets it up to not adds I assume.
Ben
Old Oct 3, 2002 | 04:10 PM
Car: 99 Formula
Axle/Gears: 342
Ben
I hope so,
but I hate to break it to ya, but with those mods, intake, exhaust,timing adv and whatever else was listed won't gain an LG4 60hp, sorry not goin to happen.
Old Oct 3, 2002 | 06:08 PM
Momar's Avatar
Originally posted by Mark A Shields
I hope so,
It wouldnt really suprise me because by then you have got rid of most the stuff that the l69 has better than the lg4 and actually have better parts than the l69 started with and it starts out with 190. I bet you could get at least 40-50. I think that they have done tests in the magazines and just adding the dual snorkle air cleaner has picked up 4 tenths on a lg4 so what would that equate to in hp?
Ben
Old Oct 3, 2002 | 08:01 PM
paul_huryk's Avatar
I hope so, but I hate to break it to ya, but with those mods, intake, exhaust,timing adv and whatever else was listed won't gain an LG4 60hp, sorry not goin to happen.
You can believe that if you want, but it is true. I did the same mods on my Camaro and IROC (both LG4 cars) and they ended up with about 225 hp.
The did not have as many parts as the camaro, but it still ran 15.1 at 92mph every damn time at E-Town, or about 225hp in a 3600lb car.
Mods:
Banks y-pipe, 3" cat, and 3" cat-back exhaust
L69 air cleaner with K&N
Edelbrock Performer EGR intake
Edelbrock Micro-plus timing computer
The car was a T5 with a 3.27 9 bolt rear on regular BFG radials and it was tuned about perfect.
I ran a little faster with my Camaro (15.0), but it also had underdrive pulleys and electric fans (IROC ran a clutch fan & stock pulleys).
The only 2 advantages the L69 would still have are the compression (worth only 5-10hp) and a stronger cam (another 10hp maybe). So the two would only be at most 20hp apart if everything else was the same.
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
