Who knows alot about SLP headers and their Y-pipe?
Old Sep 11, 2000 | 05:21 PM
RSS's Avatar
RSS
I'm thinking about getting 1 3/4" SLP headers w/o air tubes. What size are the collectors and the Y-pipe? Also, how much would these cost?
BTW, I'm getting a bigger engine soon. That's why I'm getting 1 3/4" instead of 1 5/8's.
92 RS (Rice Sucks) 305 TBI 5 speed T-tops AC stock 16 inch aluminum wheels
14X3 open element, 3.73 gears, posi, dual 2 inch bendable exhaust, no mufflers or cats (kinda loud), 160 thermostat, relocated IAT, weight loss, lots-o-free mods and one hell of a crazy driver.
"Friends don't let friends drive Mustangs."
Old Sep 11, 2000 | 06:21 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The collectors and y-pipe are 2 1/4". SLP is having a special on them right now. Check out http://www.slpeng.com/ and look for the thirdgen specials.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
Old Sep 11, 2000 | 07:41 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
The y-pipe diameters are 2 1/2" ID, so I don't see how the collectors would be smaller than that.
Maybe they're 2 1/4" on the 1 5/8" headers, but I know they're 2 1/2" on my 1 3/4" headers.
Black 88 GTA L98
!Airbox, !IAT, !MAF, !TB, !Plenum, SLP 1 3/4" headers, Dynomax Hi-Flo cat & cat-back
14.389 @ 95.2 mph, 2.001 60' {Before headers, new times coming soon)
Old Sep 12, 2000 | 12:46 AM
Kevin91Z's Avatar
Are you sure? I called SLP directly and asked them about the difference between their 1 5/8" headers and their 1 3/4" headers, and they said the only difference is the size. They use the same y-pipe, 2 1/4". My dad just put a set on an 87 IROC, 1 3/4" SLP headers with a 2 1/4" y-pipe.
Old Sep 12, 2000 | 04:22 PM
Car: 88 GTA
Yeah, I'm sure. I got my set used and went through a bit of trouble finding a crush ring gasket that would work for the setup. I got one that was 2 1/2" ID first, but since that was how SLP measured their pipes it was too small. So I went back to the store and exchanged them for a slightly larger one.
Also, if you look here under header accessories, the collector donut gaskets are listed as 2 1/2" ID (but they must be slightly oversized).
Old Sep 12, 2000 | 11:43 PM
RSS's Avatar
RSS
Damn!!! What are they? I don't want them if they're gonna have 2 1/4" pipes. How about the Y-pipe exit? It's 3" right?
Old Sep 13, 2000 | 12:54 AM
Car: 88 GTA
Yes, the y-pipe exit is 3"
Old Sep 13, 2000 | 06:06 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I have the SLP 1-5/8" headers. Kevin is 100% correct. They are 2-1/4". I know this for a fact because I measured everything with my micrometer. I even posted about it a year ago on the old thridgen.org message board.
This is for the dual cat setup. GM's cats that they use on the dual cat setup are 2-1/4" in and 2-1/2" out. The SLP pipes are 2-1/4" to mate up to this. The header collectors are also 2-1/4" BUT they appear to be 2-1/2". That is probably where the discrepency is here. The 2-1/4" pipes neck-UP to 2-1/2" exactly at the collector. The header collector appears to be 2-1/2" until you measure the diameter slightly UP-stream in the collector ... then you'll see its 2-1/4". Been over this many times before and already took the measurements to solve some disputes on this matter over a year ago.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.587 @ 107.97mph (1.710 60ftr) on the long runner setup.
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels. Stock Wheels. No Weight Reduction.
Gunning for NA 11's with the MiniRam II and Hooker LT Headers.
-=ICON Motorsports=-
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Chad Speier
Sep 24, 2015 12:32 PM
aharvel50
Sep 21, 2015 07:31 PM
alpine247
Sep 16, 2015 05:25 PM
89fast5oh
Sep 8, 2015 09:55 AM
