having problems installing hooker catback!!
Old Oct 21, 2002 | 08:08 PM
cridom's Avatar
i took the things that hold the side pipes out but i cant take them out the muffler so i can take it out to take all out
n e one knows a good manual way to cut the pipes????????
Old Oct 21, 2002 | 08:49 PM
Z28DJP1987's Avatar
Check with the Hooker expect-Mark Shield. He should answer your question. Give him a minute to log on.:hail: :hail:
Old Oct 21, 2002 | 10:48 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'm a little confused. Are you having problems with the hangers to hold the pipes. Or with the exhaust pipes out the muffler?
Old Oct 22, 2002 | 06:13 AM
DakotaSLT's Avatar
Re: having problems installing hooker catback!!
I think your trying to cut the old exhaust out, right? If so, just use a sawzall with a good metal-cutting blade, and cut the pipe before and after it goes over the axle, and everything should just fall out. Just be sure to keep control of the saw though, because there are lines (brakes, etc.) that you would not want to accidentally cut.
Old Oct 22, 2002 | 11:23 AM
cridom's Avatar
thanks i needed to cut the old exhaust ill do it tonight how long is gonna take to cut it?
Old Oct 22, 2002 | 01:20 PM
Z28DJP1987's Avatar
The Hooker expect couldn't help??
rocn7roc
Sep 21, 2021 02:16 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fronzizzle
Aug 17, 2015 02:52 PM
TheJoeY88
Aug 13, 2015 06:51 PM
