exhaust installation problems
Old Oct 26, 2002 | 03:19 PM
Psyte's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 600cfm carb
Transmission: 700R4 (auto)
i cant get the freakin pipe over the freakin axel, does anyone else here have this problem?!?!? i put the car on ramps, and i still couldnt put it on, is there some kind of trick to it? how much would it cost for me to take it in to a shop to have them put on every thing from the y-pipe and back? please specify american or canadian $$$ please, thanks
Old Oct 26, 2002 | 03:49 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Aside from what I did, have you tried unbolting the trackbar brace (and trackbar as well if needed) to get that piece to fit over the rear ?
Old Oct 26, 2002 | 04:09 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You should jack the car so that the axle can drop down.
Old Oct 26, 2002 | 04:33 PM
SIMON HOLTBY's Avatar
I drove my car to a garage having removed the muffler as I was unable to remove the intermediate pipe. The guy put it on a vehicle lift the type that lifts the wheels and we were unable to remove the pipe. He then jacked up the back of the car and it came out but was difficult then obviously put the new one in.
Cost me £5
As was mentioned earlier removing the track bar helps
simon
Old Oct 26, 2002 | 09:54 PM
Psyte's Avatar
those are some good ideas. where can i jack the rear of the car up though? i tryed to do it before on the notches provided near the rear tires, but they started to bend, and i dont feel real safe under there when its only being held up by 2 really thin peices of metal.
Old Oct 26, 2002 | 10:54 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Old Oct 28, 2002 | 08:14 PM
Psyte's Avatar
ok........ but where is a good spot on the frame to do it so i dont end up warping it
Old Oct 28, 2002 | 09:27 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
best way would be to slip jack stands underneath the rear subframe rails. Be careful, though, the sheet metal will bend if you load it at one point. Then remoe the jack form the rear and itll now be unloaded so you can work on it.
Vintageracer
Jan 10, 2020 05:33 PM
db057
Aug 22, 2015 08:17 PM
gta power
Aug 13, 2015 06:15 AM
drathaar907
Aug 6, 2015 04:20 PM
